Old Thu, Dec-27-2018, 10:22:46 PM   #31
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
Default Re: differential whine
The second you add poly bushings to the diff, it whines... that is all.
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@_Frank_Stone_
Jump to top OneFastSicilian is offline   Reply With Quote
Old Sun, Dec-30-2018, 02:39:52 PM   #32
E46Hoonigan
E46Hoonigan's Avatar
Reputation: 0 E46Hoonigan is on a distinguished road
Originally Posted by chsbmw View Post
Thatís good to know thanks. Diff is going back to the builder this week. Want it corrected where the whine goes back to how it was prior to rebuild and then will contemplate on going the OEM route.
Perhaps going back to OEM will help with the thump as well. Shop is throwing on a new DM flywheel to see if that helps with the clunk/thump. Takes away from the whole driving experience.
I used to have a JB racing aluminum single mass flywheel and it whined like an absolute *****. I am ever so glad that I switched back to a OEM DM flywheel.
Instagram: sid_e46
CarbonBlack/Cinnamon E46 M3
Koni/Vogtland, Apex ARC-8 18" Square/PS4s, Powerflex, Megan Racing Sec. 3, WPC Rod Bearings, ECS OCC, Besian VANOS, Mishimoto Electric Fan, 3.91 Gears, 996 Brembo, OEM CSL Trunk/Diffuser
Alpine White/Sakhir Orange F10 M5 Comp
Stage 1 Vargas Turbo Upgrade
Jump to top E46Hoonigan is online now   Reply With Quote
Old Sat, Jan-05-2019, 08:38:01 PM   #33
aznbo187
XIII
aznbo187's Avatar
Originally Posted by Toxic0n View Post
Don't all diffs whine and the poly bushings just transmit the noise better?
I have OE bushings and after installing the Mason brace, I can hear the diff whine with the seats down at highway speeds.
Recently got solid subframe bushings + brace + OE diff bushings and fresh OE fluid.
I'm also getting some 70-85mph diff whine it sounds like (speed dependent, not RPM).
What subframe bushings did you go with? I'm suspecting even OE diff bushings but solid subframe plus brace = more noise also.
no.13
Old Wed, Jan-09-2019, 10:10:43 PM   #34
Toxic0n
I still have the original subframe bushings in there They looked fine when I was installing the Mason brace, going to replace them this year along with diff bushings. Will stick to OE.
Ground Control, Mason Engineering, HRE, ACS, Rogue Engineering
Jump to top Toxic0n is offline   Reply With Quote
Discussing differential whine in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
