Old Sun, May-05-2013, 02:52:50 PM   #11
paffy
Reputation: 0 paffy is on a distinguished road
Czech_Republic
Default Re: differential whine
It's going back first thing Monday.
So much for extra 2 day delay from installer because "we want to test drive it".
P.
http://www.msstuning.com/ - serving your MSS5x flashing needs
2014 BMWCCA NY autox E class champion
My GTS4 build journal - http://www.m3forum.net/m3forum/showthread.php?t=551613
Jump to top paffy is offline   Reply With Quote
Old Sun, May-05-2013, 03:22:23 PM   #12
x Spades x
Reputation: 0 x Spades x is on a distinguished road
Screw my last comment... that is not a bushing problem. That sounds is the gear. Point blank period.
Jump to top x Spades x is offline   Reply With Quote
Old Sun, May-05-2013, 03:35:25 PM   #13
nickpiper12
nickpiper12's Avatar
Reputation: 0 nickpiper12 is on a distinguished road
Yea that is awful in the video. I thought I had bad diff whine, but you have really bad diff whine lol. I also brought my car back in to the installer yesterday. Hopefully both of our issues will get sorted out.
2003.5 E46 M3 SMG | Alpine White/Black
2000 E46 "M3T" 6MT | Steel Grey/Tanin Red
2011 E91 Touring Sport 6AT | Alpine White/Chestnut Brown
Jump to top nickpiper12 is online now   Reply With Quote
Old Wed, May-08-2013, 11:29:37 PM   #14
paffy
Czech_Republic
What's normal rotational play on the diff input shaft ?
On mine it moves almost 1/4" where the bolts connecting driveshaft to diff. are.
Is that too much ? Too little ? Just about right ?
Old Thu, May-09-2013, 02:24:54 PM   #15
Reach
Reach's Avatar
Reputation: 0 Reach is on a distinguished road
Just right / normal. I've seen another local car with new reman shafts that had that much or more play.
PS> did you ever answer the bushing question? Do you have OEM bushings at all 3 diff mount points?
Jump to top Reach is offline   Reply With Quote
Old Thu, May-09-2013, 05:43:51 PM   #16
paffy
Czech_Republic
ushings are OEM, but it's not related. I'm picking up a spare diff tonight and doing a swap for now
Old Thu, May-09-2013, 07:00:16 PM   #17
ruffy dongles
Reputation: 0 ruffy dongles is on a distinguished road
Please keep us updated. I have a 4.10 r+p waiting to go in and was going to take it to Turner. Curious to hear what they say.
IG @mannschaftschnell
Jump to top ruffy dongles is offline   Reply With Quote
Old Fri, May-10-2013, 02:18:36 AM   #18
Shadytype
Undercarriage checker
Reputation: 0 Shadytype is on a distinguished road
That is the tolerance on the r and p. it's too close and needs to be shimmed out.
The noise will wear in a bit but it won't get rid of it all. There is too much pressure on the ring gear from the pinion and this will result in excessive heat and wear. Remember tolerance like this are so close that even a sheet of paper thickness can make it fugg up.
Jump to top Shadytype is offline   Reply With Quote
Old Fri, May-10-2013, 02:30:52 AM   #19
M3_mann
Reputation: 0 M3_mann is on a distinguished road
It sounds like there's no fluid in that box!
2008 Space Grey/Extended Black ///M3
2003 A07/Imola ///M3
Past BMWs-
2006 Interlagos Blue ZCP 6mt E46 ///M3
2003 Imola Red SMG, 2003 Carbon Black 6mt E46 ///M3
2004 & 2005 Mystic Blue E46 ///M3 6mt
1990 E30 325is - S52 Swapped
1987 Euro E30
Jump to top M3_mann is offline   Reply With Quote
Old Fri, May-10-2013, 03:26:22 AM   #20
paffy
Czech_Republic
Yes, it sounds like there's no fluid, but it's there - I checked.
To me it actually feels like it's too loose, not tight. The backlash feels larger than on the 65k miles used diff I just picked up !
I'll be pulling it tomorrow.
P.
Discussing differential whine in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
