Old Fri, May-03-2013, 05:28:04 AM   #1
paffy
Reputation: 0 paffy is on a distinguished road
Czech_Republic
Default differential whine
I just got a rebuilt diff with 3.91 ring & pinion installed.
The car sounds like it's got straight cut gear gearbox. Both loaded and unloaded drive-train makes whining noise. When I find neutral throttle to minimize the torque on the driveshaft, the whine goes away, so I'm 95% sure it's the R&P.
Is this normal ? Will it go away ? The gears are not polished AFAIK.
P.
http://www.msstuning.com/ - serving your MSS5x flashing needs
2014 BMWCCA NY autox E class champion
My GTS4 build journal - http://www.m3forum.net/m3forum/showthread.php?t=551613
Jump to top paffy is offline   Reply With Quote
Old Fri, May-03-2013, 03:43:08 PM   #2
RedM3/4
Default Re: differential whine
You hear of folks getting rid of a little bit of whine, usually just off-throttle (my car has recently started this on longer trips at expressway speeds) with fresh fluid/more friction modifier. But I don't think I've ever heard of one that whines newly installed, getting better. Further, if you drive it much at all, it is now worn in wrong and taking it back probably won't fix it. Take it back to the installer NOW is my recommendation.
ADS
06 SMG/ZCP - April 09, MCS 2WR (replaced Dinan over Konis/replaced OE), Supersrpint street section3, RAC RG63, homelink with off-delay, multifunction steering wheel buttons, RacingBrake Front kit.
Old Fri, May-03-2013, 04:12:23 PM   #3
waldron80
waldron80's Avatar
Reputation: 0 waldron80 is on a distinguished road
Did you install new bushings? Oem or poly?
My RTAB Experience - Don't do what I did....
Often requested Tire Size Calculator -- My 3.5mm AUX install -- My home grown Maintenance Spreadsheet
Jump to top waldron80 is offline   Reply With Quote
Old Fri, May-03-2013, 04:23:18 PM   #4
Abad46
Abad46's Avatar
Reputation: 0 Abad46 is on a distinguished road
The BMW gearsets use super tight backlash tolerances, if the gear was previously used (or setup too loose) it will whine like crazy.
Jump to top Abad46 is offline   Reply With Quote
Old Fri, May-03-2013, 04:42:10 PM   #5
x Spades x
Reputation: 0 x Spades x is on a distinguished road
Did you replace all bushings? Also, the gears might be set to tight (not enough gap between teeth). These are the only things that will cause whine. Take back asap as the gears will wear wrong and you are screwed. Usually gears break in within 700 miles.
Jump to top x Spades x is offline   Reply With Quote
Old Fri, May-03-2013, 05:52:38 PM   #6
Reach
Reach's Avatar
Reputation: 0 Reach is on a distinguished road
If you put in solid bushings, they will transmit the noise by themselves.
If you're on OEM bushings, then I'd point to the R&P install, and have it fixed asap.
Jump to top Reach is offline   Reply With Quote
Old Fri, May-03-2013, 05:54:46 PM   #7
paffy
Czech_Republic
The differential is a fresh rebuild from Turner. They just told me to expect some whine before it breaks in and change diff fluid after 1200 miles.
I've put 30 miles on it so far, I guess I will be taking it back to the shop just to make sure.
P.
Old Sun, May-05-2013, 06:11:12 AM   #8
paffy
Czech_Republic
noise start at 0:30
Old Sun, May-05-2013, 07:00:59 AM   #9
chubafg
Reputation: 0 chubafg is on a distinguished road
Jump to top chubafg is offline   Reply With Quote
Old Sun, May-05-2013, 11:48:34 AM   #10
m3e46freak
M3 Freq
m3e46freak's Avatar
Reputation: 0 m3e46freak is on a distinguished road
Germany
I agree 100% awful and needs to be properly diagnosed. The sound I do not think can be stopped with the BMW XFM booster...but you can try.
2009 r8 v10 White/Cinnamon
RIP
Rock Hard Abs Racing
KWV2!
18X10 CCW CLASSIC!
CPI Headers!
RESONATORS AND SUPERSPRINT!
DINAN!
FRANK!! 311RWHP-260Torque
CSL bumper - hack job from status gruppe.
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
Jump to top m3e46freak is offline   Reply With Quote
Discussing differential whine in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
