Old Thu, Jan-10-2019, 09:11:20 PM   #1071
.'s Avatar
Reputation: 0 . is on a distinguished road
Default Re: The Official E46 M3 Oil Analysis Results Thread
Liqui must translate to "Less" in German or something
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, ARP head studs, Epic Motorsports tune, TMS Power Pulleys, ECS catch can, SS V1 stepped headers & catless section 1, SS 2.5 twin-piped resonated section 2, SGT scza section 3.
Drivetrain: Clutch Masters FX725, Clutch Masters Hydraulic TB, RTD V2 mini shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings, mason clutch pedal.
Suspension/Brakes: Bilstein PSS9's, RE RSM's, UUC sway bars, PFC direct drive rotors, PFC 08's, Nitto NT05's, Motorsport Hardware 75mm stud kit.
Coming soon: Cobra Nogaro seats, BW Street/Track rear camber arms, Turner monoball RTAB's.
IG: Zach_e46M
Jump to top . is online now   Reply With Quote
Old Thu, Jan-10-2019, 09:35:01 PM   #1072
Mpowerzz
Reputation: 0 Mpowerzz is on a distinguished road
So liqui moly is not good for street? That's the current oil im using now, since the previous owner told me to use it. I just recently did a oil change, Im going to send it to blackstone.
Jump to top Mpowerzz is offline   Reply With Quote
Old Thu, Jan-10-2019, 10:22:12 PM   #1073
/M3
/M3's Avatar
Reputation: 0 /M3 is on a distinguished road
Just got a 2006 ZCP with 156K. Castrol TWS all it's life. Per the previous owner, Blackstone results were fine at 146K. Just put Motul 10w-60. Will change again with Motul at 160K. Then I'll have a Blackstone report with a 5K interval.
"Laguna Seca Blue 448. BMW nail it with this color. It defines an E46 M3."
Jump to top /M3 is online now   Reply With Quote
Old Thu, Jan-10-2019, 10:34:22 PM   #1074
ThunderMoose
Nice one!
#67 2017 NASA TX TT3 Champion
Old Thu, Jan-10-2019, 11:11:43 PM   #1075
Texaz3
LM 10W60 is just fine for street or track. Been using it for years on all my cars.
Old Fri, Jan-11-2019, 12:00:23 AM   #1076
Joshe46
Joshe46's Avatar
I remember some time ago hearing in this forum liqui moly lacks molybdenum. I could be completely mistaking my information here but thats what I remember.
Jump to top Joshe46 is offline   Reply With Quote
Old Fri, Jan-11-2019, 12:21:54 AM   #1077
M3_Pilot
Molybdenum doesn't make or break an oil. Not sure why some people need an oil with molybdenum. Some oil manufacturers actually avoid molybdenum because it's a solid.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Jump to top M3_Pilot is online now   Reply With Quote
Old Fri, Jan-11-2019, 01:13:11 AM   #1078
.'s Avatar
Don’t get me wrong just because it has less moly doesn’t make it inferior. I’d be more concerned about the oils cold pour and viscosity over temp characteristics. But LM loses in that category to TWS, Ravenol, etc as well.
IG: Zach_e46M
Old Fri, Jan-11-2019, 01:36:03 AM   #1079
neopolymath
neopolymath's Avatar
Reputation: 0 neopolymath is on a distinguished road
Street car = pick any of them and change every 5k and forget about this conversation
Jump to top neopolymath is offline   Reply With Quote
Old Fri, Jan-11-2019, 05:32:56 PM   #1080
Texaz3
Pretty much yeah.
Discussing The Official E46 M3 Oil Analysis Results Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
