Old Thu, Jan-10-2019, 06:03:32 AM   #41
mrgizmo04
mrgizmo04's Avatar
Default Re: Who is Running the Magnaflow Cat Back Exhaust?
Never tried that other cross-over, but yeah, drone drove me nuts. There is a thread somewhere about welding a plate connecting the two pipes to reduce/eliminate drone. I tried doing something similar, didn't seem to work, so I got rid of the system and went to SS.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Discussing Who is Running the Magnaflow Cat Back Exhaust? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
