Old Mon, May-22-2017, 05:59:25 PM   #451
02_LSB
Default DIY: Vanos hub + bolts
Delete.
Jump to top 02_LSB is offline   Reply With Quote
Old Tue, May-23-2017, 01:29:50 PM   #452
Rajvosa
Reputation: 0 Rajvosa is on a distinguished road
Default Re: DIY: Vanos hub + bolts
Hi guys,
Did the vanos overhaul last week (seals, disc, cam bolts, solenoid pack).
Passed the test after doing the work and have done about 100 miles since.
Thought I'd re do vanos test and it failed. Then I did it again and it passed ...
Here are the images :
1) failed
2) passed
Any ideas?? (Oil temp was fine to run the test. )
Jump to top Rajvosa is offline   Reply With Quote
Old Wed, May-24-2017, 06:51:19 AM   #453
bimmerdriver
Originally Posted by Rajvosa View Post
Hi guys,
1) failed
2) passed
Like it says, if it fails more than 50% of the time, there is a problem. You need to run int more than twice for a statistically significant result. If there's a problem, it's likely a damaged seal.
Old Wed, Jan-09-2019, 11:43:42 PM   #454
Zekarus
Reputation: 0 Zekarus is on a distinguished road
Germany
edit: sorry guys. didn't saw the date of his post.
Hi guys,
1) failed
2) passed
As I read in your previous post, you are using an aftermarket bridge tool. This could be the reason for your timing problems. You should have used the original BMW bridge tool.
From Beisan: "Warning: Use only Genuine BMW alignment bridge. All available aftermarket bridges are not precise and will cause wrong timing and possibly bent valves."
Jump to top Zekarus is offline   Reply With Quote
Old Thu, Jan-10-2019, 12:45:17 AM   #455
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
That is correct. If you used an aftermarket bridge it will be wrong every time
Discussing DIY: Vanos hub + bolts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
