Old Fri, Dec-02-2011, 07:26:01 PM   #11
white-hot
is lurking around the corner
white-hot's Avatar
Default Re: Underdrive Power Pulleys
As m3_larry said, the pulley IS the harmonic balancer. If you like your engine running out of balance it is fine to remove. Anyone that said they removed it and all was well are likely full of $hit.
Old Sat, Dec-03-2011, 06:45:31 PM   #12
max5roadster
Reputation: 0 max5roadster is on a distinguished road
There was a company that actually made underdriven crank pulleys with the harmonic balancer portion (essentially a chunk of rubber), but iirc their selection was pretty limited. Some food for thought: early miatas that run under driven cranks end up with shattered oil pumps, so on this one, mod at your own risk.
98 M3 Vert
Intake, ASC Delete, Fan Delete Mod, 3.91 LSD Swap, Alumn Radiator, Lightweight Battery, R1 Slotted/Crossdrilled rotors f/r
Jump to top max5roadster is offline   Reply With Quote
Old Sun, Dec-04-2011, 05:57:28 PM   #13
kingchris
kingchris's Avatar
Reputation: 0 kingchris is on a distinguished road
The turner kit is a reputable one. You have the choice of under driving the alternator. The major benefit of a pulley kit is that it replaces that plastic water pump pulley with a metal one. There are no reputable dealers that touch the crank. Just don't....
98 BMW M3: Cosmos Black w/Magma int.
87 Buick Grand National: Black w/Grey int.
Jump to top kingchris is offline   Reply With Quote
Old Sun, Dec-04-2011, 06:16:54 PM   #14
Sharocks
Reputation: 0 Sharocks is on a distinguished road
Ive got the Rogue Engineering kit on my car. I like and recommend!
Jump to top Sharocks is offline   Reply With Quote
Old Sun, Dec-04-2011, 06:55:26 PM   #15
boomersooner523
boomersooner523's Avatar
Reputation: 0 boomersooner523 is on a distinguished road
Does rouge use a under driven crank pulley?
Current:
Euro 2002 Imola Red E46 M3 6spd: KW V2, Stoptech ST-40, Active Autowerke Gen IV, Mason Engineering Strut brace, RE RSM's, OEM SSK, AKG subframe bushings, TMS Rtab limiters, TMS subframe plates, Escort 9500ix, Focal speakers
Past:
1999 Cosmos M3- Koni/Eibach, M50, TRM tune, ASC delete, PowerFlex bushings everywhere, SS lines, much more
1995 Hellrot M3- H&R Sports, JB Racing 10lb flywheel, Dinan exhaust
Jump to top boomersooner523 is offline   Reply With Quote
Old Sun, Dec-04-2011, 08:00:54 PM   #16
EmDeeAr
EmDeeAr's Avatar
Reputation: 0 EmDeeAr is on a distinguished road
No it does not. Both UUC and Rogue only under-drive the water and power steering pumps. Both are quality kits. Can't go wrong with either.
Jump to top EmDeeAr is offline   Reply With Quote
Old Sun, Dec-04-2011, 08:42:50 PM   #17
white-hot
white-hot's Avatar
None of the kits available will have the UD on the crank.
Old Sun, Dec-04-2011, 09:41:28 PM   #18
Sharocks
They said it! It's a great kit I love it!
Old Sun, Dec-04-2011, 11:34:52 PM   #19
boomersooner523
Awesome. Thanks for the info guys. Its on my to-do list now!
Current:
Past:
Old Mon, Dec-05-2011, 01:27:05 AM   #20
EmDeeAr
EmDeeAr's Avatar
Let us know of any findings and gains, boomer.
Discussing Underdrive Power Pulleys in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
