Old Thu, Jan-10-2019, 01:08:06 AM   #1
kaiv
SoCal S54 specialist :P
kaiv's Avatar
Reputation: 0 kaiv is on a distinguished road
France
Default PPF clear bra removal tips?
I have clear bra that has failed due to time and exposure and is proving very tough to remove. I've tried using heat to soften it but that didn't help. It shears off in extremely tiny pieces. It took me an hour to do a small portion of the hood and I still have the full bumper, fenders, trim below the headlights, mirrors...
E46 ///M325i Touring journal
Kaiv's SoCal Feedback! IG: limited.slip
Jump to top kaiv is offline   Reply With Quote
Old Thu, Jan-10-2019, 01:11:56 AM   #2
oceansize
Kwisatz Haderach
oceansize's Avatar
Reputation: 0 oceansize is on a distinguished road
Default Re: PPF clear bra removal tips?
Some good info...
2003 M3 Convertible SMG w/Hardtop | GC Coilovers and Camber Plates 500/600 | ESS VT1-475 Gen 3 Supercharger | Stoptech Brakes
Apex ARC-8 19" Hypersilver | CSL SMG (and 255) Tune | Rogue Eng. Diablo Exhaust w/ SS Tips | Rogue Eng. Rasp Pipe
Redish Reinforcement Plates | Polyurethane Rear Subframe Bushings | Polyurethane Differential Bushings | Beisan Oil Pump Disk
Jump to top oceansize is offline   Reply With Quote
Old Thu, Jan-10-2019, 01:40:43 AM   #3
lmtfi
lmtfi's Avatar
Park it in the sun on a warm-ish day, peel up and edge and keep pulling. Key is to let the sun warm it up fully.
If it fragments - you should have removed it years before. You may have to pay a pro to do it. Kind of looks like a basket case.
Old Thu, Jan-10-2019, 02:02:26 AM   #4
I've heard steam works well
Old Thu, Jan-10-2019, 03:43:57 AM   #5
Kdubski
Kdubski's Avatar
Reputation: 0 Kdubski is on a distinguished road
3m has commercial grade adhesive removers that I've used on similar situations. Soak some shop towels in it and lay over the area where you started undoing the clear bra. Then scrape with plastic razors.
Sent from my SM-N950U using Tapatalk
Jump to top Kdubski is offline   Reply With Quote
Old Thu, Jan-10-2019, 03:57:18 AM   #6
Oregon1911
BMW CCA 35-Year member, NRA Life-Member
Oregon1911's Avatar
Reputation: 0 Oregon1911 is on a distinguished road
Heat gun prudently applied followed by penetrating oil to remove residual ****. It takes time so don't get impatient. Good luck.
Dinan Stage 1 flash, Dinan Stage 1 suspension, 6MT, CSL 19" wheels, ZHP shift knob, "M-Clunk" limited edition oil filter cap.
Jump to top Oregon1911 is offline   Reply With Quote
Old Thu, Jan-10-2019, 04:24:27 AM   #7
toy4to
Lemonade Tycoon
Reputation: 0 toy4to is on a distinguished road
Kaiv, I install paint protection film as a side gig. I've removed a lot of old ppf. Best way is to use a steamer. Heat it up and slowly peel alway. Lots of steam will do it.
If you have a tough time, use plastic razor blades and 3M Adhesive remover to remove the leftover residue.
https://www.ebay.com/itm/3M-08984-Ge...EAAOSwXzNaX8-~
On Amazon, search for single edge plastic razor blades. They're around $6 for 100.
Jump to top toy4to is online now   Reply With Quote
Old Thu, Jan-10-2019, 06:32:27 AM   #8
grke36m3
Reputation: 0 grke36m3 is on a distinguished road
Plastic razor blades time and stoners bug and tar remover eats up any adhesive left over.
Jump to top grke36m3 is offline   Reply With Quote
Old Thu, Jan-10-2019, 06:45:13 AM   #9
HassanEido
HassanEido's Avatar
Lebanon
ughh ...
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Thu, Jan-17-2019, 11:10:35 PM   #10
kaiv
kaiv's Avatar
France
Thank you so much.
This isn't the most fun I've had but it's all gone now!
The film on the horizontal surfaces was so cracked, there was no peeling it off in one piece.
The plastic razor blades were invaluable.
Thanks all!
Discussing PPF clear bra removal tips? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
