Old Sat, Feb-27-2016, 08:27:45 PM   #41
tmaxx445
Likes to Eat AMGs
tmaxx445's Avatar
Reputation: 0 tmaxx445 is on a distinguished road
Default Re: Auto leveling on ZCP?
Set the mileage to 0. It'll automatically sync up with the IKE if the VIN matches.
Thanks!
2005 M3 Coupe / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium / Cold Weather / Bi Xenons / Adjustable Bolsters / Lumbar / MKIV Navigation / Harmon Kardon Hifi / Sirius / Aux In / Bluetooth / Rain Sensor / Home Link / BMW Assist / Alarm / Hard Wired Radar Detector / LED Interior Lights / Carbon Interior Trim / Alcantara Pillars / ZHP Shift Knob / Short Shifter / Custom Tune / StreamLine Intake / IAT Relocation / Dynamic Air Scoops / Fan Delete / SS Headers / AR20 Resonator / Electric Exhaust Bypass Valve / Koni Yellow Adjustables / Eibach Pro Kit Springs / PowerFlex & AKG Poly Bushings / M Track Mode / RedLine Fluids / PFC Z-Rated Street Pads / Staggered OEM CSLs / 275 & 245 595 Evos / 12mm Front Spacer / 10mm Rear Spacer / Orion V2 Angel Eyes / Carbon CSL Splitters / Matched Reflectors / SunTek Carbon 38% Tint
Jump to top tmaxx445 is offline   Reply With Quote
Old Sat, Feb-27-2016, 08:28:25 PM   #42
Set mileage to 0 with PASoft, read ZCS from IKE, go to LCM, SG_CODIEREN (blank FSW_PSW), ZCS_SCHRIBEN, FGNR_SCHRIBEN
Old Sun, Feb-28-2016, 01:17:07 AM   #43
tmaxx445
Likes to Eat AMGs
tmaxx445's Avatar
Thanks guys, I zeroed out the millage in PA Soft then cycled they key and it synced the VIN and millage automatically. No tamper dot; also added the correct VIN to the Bluetooth assist module while I was in there too. I coded a blank trace file with NCS then read it back out and tweaked a few parameters in the file to suite my liking.
The new LCM.C34 I grabbed from the 5/06 e53 had the parameters for the dynamic aim for acceleration and deceleration and I gave it a quick blast around the block and I can see for sure they dip down a split second after hard acceleration in second gear for instance. It did have to be made active in the trace file after it was factory default coded for the e38 though.
It's odd I have never noticed my 10/04 M3 behaving this way before but I have never really watched that closely along a wall while accelerating. Maybe it need to be activated on that car as well? When did you think this was added to the e46 LSZ Terra?
Old Mon, Mar-07-2016, 01:21:37 AM   #44
Vmals89
Vmals89's Avatar
Reputation: 0 Vmals89 is on a distinguished road
The auto leveling did not work on my M5 when I bought it (auto leveling arm was snapped, common e39 failure). I repaired it, and it was a huge increase in the usefulness of the headlights. Even more so once I retrofitted high quality projectors with sharp cutoffs and a modern 55w xenon system.
Which projectors are you running on the M3?
Jump to top Vmals89 is offline   Reply With Quote
auto leveling, headlight, zcp
Discussing Auto leveling on ZCP? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
