Old Mon, Feb-22-2016, 10:13:42 PM   #11
Default Re: Auto leveling on ZCP?
Originally Posted by camberm3 View Post
No, it's not.
Auto leveling only works at startup, which is when it aims your headlights based on passenger and cargo load. Hence the down and up zeroing in procedure you see and hear. However, after that, it does nothing. If you don't carry passengers and/or big loads, it is unnecessary. Many people are under the false impression that the lights adjust while you are driving. They don't.
Test it out for yourself by slowly driving towards a wall through uneven pavement. Then repeat the same identical test with the auto leveling plugs disconnected. Beam hight will be identical for both.
That doesn't test if that's how it functions.
Driving at the same wall twice, once alone, once with a couple hundred pounds in the trunk, with the car on continuously between, would.
Old Mon, Feb-22-2016, 10:25:36 PM   #12
Here: it updates and resets every 25 seconds. BMW's tech document describing the functionality attached.
File Type: png Screen Shot 2016-02-22 at 6.24.21 PM.png (489.4 KB, 164 views)
Old Tue, Feb-23-2016, 12:02:45 AM   #13
I suspect newer LCMs refresh more frequently or possibly proactively rather than reactively. I know I've gotten them to adjust with hard acceleration and braking. Iirc they may also adjust a bit higher if you're driving 120mph or so
Old Tue, Feb-23-2016, 12:26:34 AM   #14
I suspect newer LCMs refresh more frequently or possibly poractively rather than reactively. I know I've gotten them to adjust with hard acceleration and braking. Iirc they may also adjust a bit higher if you're driving 120mph or so
Completely agreed-- I've seen them react while driving.
But, the only tech document I could find mentioning the function was from 1998
Old Tue, Feb-23-2016, 12:55:15 AM   #15
Yeah, I don't know if BMW ever released notes on how it works with newer cars. NCS Dummy gives some hints though
Code:
ANHEBUNG_175_KM/H           00000410 (01)                                         1F
    wert_01                     19                                                    19                                                    value 01        E46
    wert_02                     17                                                    17                                                    value 02
    wert_03                     01                                                    01                                                    value 03
ABSENKUNG_10_KM/H           00000410 (01)                                         E0
    wert_01                     05                                                    A0                                                    value 01        E46
    wert_02                     04                                                    80                                                    value 02
VMAX_BESCHLEUNIGUNG         00000411 (01)                                         0F                                                    MAXIMUM SPEED ACCELERATING
    wert_01                     09                                                    09                                                    value 01        !LSZ_CI_29,LSZ_CI_29+!(ALLRAD,S54B32),LSZ_CI_29+ALLRAD
    wert_02                     0C                                                    0C                                                    value 02        LSZ_CI_29+S54B32+!CSL,LSZ_CI_29+S54B32+CSL
    wert_03                     0A                                                    0A                                                    value 03
    wert_04                     09                                                    09                                                    value 04
VMIN_BESCHLEUNIGUNG         00000411 (01)                                         F0                                                    MINIMUM SPEED ACCELERATING
    wert_01                     08                                                    80                                                    value 01        !LSZ_CI_29,LSZ_CI_29+!(ALLRAD,S54B32),LSZ_CI_29+ALLRAD
    wert_02                     0A                                                    A0                                                    value 02        LSZ_CI_29+S54B32+!CSL,LSZ_CI_29+S54B32+CSL
    wert_03                     09                                                    90                                                    value 03
    wert_04                     08                                                    80                                                    value 04
VMAX_BREMSEN                00000412 (01)                                         0F                                                    MAXIMUM SPEED BRAKING
    wert_01                     08                                                    08                                                    value 01        E46
VMIN_BREMSEN                00000412 (01)                                         F0                                                    MINIMUM SPEED BRAKING
    wert_01                     04                                                    40                                                    value 01        E46
"ANHEBUNG_175_KM/H" suggests that the lights are raised when driving faster than 175km/h, and "ABSENKUNG_10_KM/H" suggests that the lights are dipped below 10 KM/H. There are also parameters that have to do with acceleration and braking, suggesting the LSZ does respond to acceleration and braking
Old Tue, Feb-23-2016, 12:57:34 AM   #16
Silvertail
Reputation: 0 Silvertail is on a distinguished road
It does adjust itself not just on cold start. I notice it every time I get into my driveway at night. My driveway has a steep slope that I have to go up just like a speed bump before I actually drive up my driveway. The light would angel down once I started giving gas to get up the slope and then it would go back to straight once the front tires gets on top of the slope. Hard to notice unless you see the sharp cutoff line with an upgraded clear lens or projector.
Jump to top Silvertail is offline   Reply With Quote
Old Tue, Feb-23-2016, 07:15:08 PM   #17
t3ddftw
t3ddftw's Avatar
Reputation: 0 t3ddftw is on a distinguished road
According to the BMW doc, the lights should point all the way down and then all the way up before leveling out when the key is turned to position two -- Will this always happen? I've never noticed it happen which makes me wonder if my steppers are broken.
Does anyone know if inoperable steppers would throw a code in the LCM?
2006 M3 ZCP 6MT Interlagos Blue on Cinnamon interior
Mods
Engine: Full Beisan Systems VANOS rebuild
Transmission: CDV Delete
Exterior: Smoked Corners | Black Side & Kidney Grills | Painted Reflectors
My Build/OCD thread
Jump to top t3ddftw is online now   Reply With Quote
Old Tue, Feb-23-2016, 07:36:07 PM   #18
VNG704
VNG704's Avatar
Reputation: 0 VNG704 has disabled reputation
Originally Posted by silvergray545 View Post
I don't know that I've ever seen mine do that either. When I owned my E60, the headlights would go up, down and side to side. You couldn't miss it.
Every time I drive behind my buddy, he always tells me how my headlights are way too bright. I wonder if they're stuck pointed up or something.
Is your leveling sensor broken? They're known to break or maybe come loose. The leveling is easily seen while driving at night going over dips in the road, etc. As the front suspension (where the sensor is located) moves up or down so will the sensors mechanism, your headlight auto leveling compensates...or at least that's how I assume it works. I haven't drove my car in months but I don't recall them doing a leveling sequence at start up. Maybe they do it with out the lights on?
But under the hood is the heart of a medieval manx dog. You even look at that engine, it'll kill you. -Jeremy Clarkson on the m3
Jump to top VNG704 is offline   Reply With Quote
Old Tue, Feb-23-2016, 07:46:08 PM   #19
silvergray545
silvergray545's Avatar
I was starting to wonder the same thing too. I'll have to check and see if my sensors are still there and working.
2004 BMW M3 6MT - TiAg/Gray
2016 BMW M3 ZCP 6MT - AW/SO
2014 VW GLI 6MT - Black/Black
Instagram
E46 M3 Build Journal
Old Tue, Feb-23-2016, 08:14:06 PM   #20
pshep138
pshep138's Avatar
Reputation: 0 pshep138 is on a distinguished road
Only my driver side auto levels. Suspecting the passenger side sensor on the control arm is on the fritz. Both of them did it when I bought my car.
('05 non-ZCP)
2005 BMW M3 6MT AW/IR (RIP 04/30/16)
IG: @classyplasticlumber
Twitter: @preston_s
Jump to top pshep138 is offline   Reply With Quote
auto leveling, headlight, zcp
Discussing Auto leveling on ZCP? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
