Old Tue, Jul-23-2013, 02:52:39 AM   #11
///o5e46m3
TRAK WDW
///o5e46m3's Avatar
Reputation: 0 ///o5e46m3 is on a distinguished road
Originally Posted by bigjae1976 View Post
Can't you run a square set of the ZCP rear wheels?
+1 This is a perfect solution for you OP
HARP
Jump to top ///o5e46m3 is offline   Reply With Quote
Old Tue, Jul-23-2013, 05:11:44 AM   #12
M3ANMACHINE
@natrajusa
M3ANMACHINE's Avatar
Possibly purchase 2 rear ZCP wheels to swap on before a track day? That way the cost is less, and you can still have your staggered dd setup
2011 E90 ///M3 | Space Grey | Fox Red | DCT | ZCP | Slicktop
2008 E90 M3 | AW | 6MT | Slicktop
2004 E46 M3 | CB | SMG
Old Tue, Jul-23-2013, 01:09:25 PM   #13
eljay
Reputation: 0 eljay is on a distinguished road
Default Re: Minimizing understeer without square setup (ZCP wheels)
My initial thought was that this would look too weird on the street.
And then I saw this additional reply...
Now, that is not a bad idea as I can pick up another set of 255/35/19 street tires for a very good price.
If I can find ZCP rears for a reasonable price, this solution might just work and lets me rotate rear tires as needed.
Thank you!
Jump to top eljay is offline   Reply With Quote
Old Tue, Jul-23-2013, 04:52:54 PM   #14
M3ANMACHINE
@natrajusa
Thank you!
I believe tischer bmw stocks them.
Also, if you want to run a square setup full-time, do it. It looks phenomenal
Old Wed, Jul-24-2013, 06:07:52 PM   #15
eljay
I looked at some pictures of a square ZCP rear setups and I just don't like the look. For track, I don't care, so I'll still look into the cost of that option, especially after reading the wheel weights of the OEM 18s are noticeably higher than ZCP 19". Then again the tire wall on the 18" may just make up for that difference in grip even with the same tire width, right?
Another option I'm thinking about is finding a set of front OEM CSL wheels (19x8.5") and put 255/35/19 on those with 255/35/19 in the rear. I should be able to fit 255s on an 8.5" wheel, correct?
That would probably be a nice handling setup that I can run full-time street/track. I guess the downside would be that I won't be able to rotate wheels front to back. But maybe I'd go through the trouble of switching the back tires to the front half-way through their tread life.
Again, this would only be cost effective if I can find a deal on OEM CSL fronts, which is probably never gonna happen!
What do you guys think of this idea?
Old Wed, Jul-24-2013, 06:24:50 PM   #16
M3ANMACHINE
@natrajusa
4 rears will be better. 8.5" square is too small
Old Wed, Jul-24-2013, 06:42:20 PM   #17
Vdub_FTW
Vdub_FTW's Avatar
Reputation: 0 Vdub_FTW is on a distinguished road
To get less understeer, a cheaper route would be to run slicks up front and A/S tires in the rear with a sway bar on the rear on full stiff and run shocks full stiff. That should get you some nice rotation LOL.
If you're a novice, I don't think you want too much oversteer.
Get camber plates and better tires or run a square set up and play with pressures or do both.
Remember, insanity is doing the same thing over and over again and expecting different results. =)
Good luck.
HULK SMASH!!!
platte forme a.g. - It's all in the setup
Jump to top Vdub_FTW is offline   Reply With Quote
Old Sun, Jul-28-2013, 03:13:05 AM   #18
admranger
Registered troublemaker
Swap the strut hats. Then pull the struts upright in the slots to minimize the camber. No more understeer problems. In fact, you'll need to balance w/tire pressure to stop from oversteer rearing it's head.
'11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
Old Tue, Aug-13-2013, 03:24:09 PM   #19
eljay
Good luck.
LOL, I'm looking for more neutral ride, not 911-style with the rear tailights checking whether the front blinkers are still working at every turn.
Well, I decided to look for two ZCP rear wheels.
My plan is put my two new 255 tires on those and put them onto the rear of the car and then take my existing rears with near-worn 255s and put them on the front the night before driving to the events. I think, currently, this will give me the cheapest way to a square setup and I'll only have to swap 2 wheels and I can drive to the event on them.
I think I will also need a 10mm spacer for the rear though, so if I leave that on there full-time, the understeer on the street will be much worse. Hmm...
These days we can push a button to adjust damping of suspension and engine mounts. Let's hope the next invention is to adjust the track width and camber at the push of a button.
Old Fri, Aug-16-2013, 10:09:35 PM   #20
Nihilation
Nihilation's Avatar
Reputation: 0 Nihilation is on a distinguished road
Just to add -- I've been running swapped strut hats for the past 15k miles on Michelin Pilot Super Sports with perfect tread wear all the way across. This setup with Eibach Pro-Kit springs on Koni Yellows provides 3.5 degrees of camber. My car is also my daily driver, seeing 80% highway and very little track time unfortunately.
Even with a square tire setup chances are you're still going to understeer until you add camber. So given the choice, I'd be swapping strut hats.
Jump to top Nihilation is offline   Reply With Quote
245/35/19, front, understeer, zcp
Discussing Minimizing understeer without square setup (ZCP wheels) in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
