Old Fri, Jan-12-2018, 12:49:54 AM   #1
Hudson0311
Reputation: 0 Hudson0311 is on a distinguished road
Default SMG to 6MT clutch switch(switch chain friction connection)
So my friend was trying to get shift light features on his 04í JP spec 6mt (originally SMG), coding part was fine, but I think thereís no signal from clutch pedal, he can start the car without stepping on the clutch. I have done some research but didnít see any SMG to 6MT about this, only a module on ECS. Anyone has experienced this? How do you solve this?
NorCal
Jump to top Hudson0311 is offline   Reply With Quote
Old Fri, Jan-12-2018, 01:04:58 AM   #2
Drewster
Drewster's Avatar
Default Re: SMG to 6MT clutch switch(switch chain friction connection)
I'd start with replacing the clutch switch and making sure it's wired/ coded properly...
Discussing SMG to 6MT clutch switch(switch chain friction connection) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
