Old Thu, Jan-11-2018, 11:39:41 PM   #1
JABRM3
Unregistered Abuser
JABRM3's Avatar
Reputation: 0 JABRM3 is on a distinguished road
Kyrgyzstan
Default Style 162 wheels on M3 ZCP
Wheel Guru's
Would Style 162 wheels fit on a Comp Edition M3 without spacers etc.. ?
The 162's are F 8x18 ET34 - R 8.5x18 ET37
Currently have OEM ZCP F 8x19 ET47 - R 9.5x19 ET27
These specifications are accurate however they are foreign to me.
Thank you.
Jump to top JABRM3 is offline   Reply With Quote
Old Thu, Jan-11-2018, 11:49:51 PM   #2
Default Re: Style 162 wheels on M3 ZCP
No just no. I don't want to type more, just trust me.
-NA S54-
·Besian · RE pullies/fan delete · WPC rod bearings · GroundControl S/A (Koni/Eibach 440/550) + tall RSMs · TMS Camber & Subframe plates · SPC Adj alloy rear camber arms
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
Old Fri, Jan-12-2018, 12:12:26 AM   #3
JABRM3
Unregistered Abuser
JABRM3's Avatar
Kyrgyzstan
Unfortunately I am not in the trust business.
They would be for a winter setup. Not looking for style points.
Old Fri, Jan-12-2018, 12:25:33 AM   #4
I wish people would post why they're asking. Looking for track wheels, street and winter wheels are worlds apart, how are supposed to know what you want?
Rear et37- I don't know if that will fit, inside of the rim might hit things is so sunken in. Of course it'll look ridiculous, but you don't care about that I guess.
-NA S54-
Old Fri, Jan-12-2018, 01:21:28 AM   #5
Joshe46
Joshe46's Avatar
I agree with Tbone your rear fitment will be ungodly disgusting. It will look worse than the front fitment does with stock wheels. *barf
Jump to top Joshe46 is offline   Reply With Quote
Old Sat, Jan-13-2018, 07:39:03 AM   #6
JABRM3
Unregistered Abuser
JABRM3's Avatar
Kyrgyzstan
Appreciate the insight. Thank you.
Old Sat, Jan-13-2018, 09:45:29 AM   #7
m3vancity
Reputation: 0 m3vancity is on a distinguished road
spacer. problem solved.
Jump to top m3vancity is online now   Reply With Quote
Discussing Style 162 wheels on M3 ZCP in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
