Old Fri, Jan-12-2018, 07:10:08 PM   #31
Default Re: Mitigating Cold Start Wear
I reprogrammed my cars with CSL warm-up light values, and they're pretty reasonable-- I actually follow them.
Old Fri, Jan-12-2018, 07:11:11 PM   #32
gam3cock
Reputation: 0 gam3cock is on a distinguished road
Wait, so quick question. (dont mean to thread jack)
I read in a few posts that it wasn't ideal to idle the car until "warm." Is this true? I have been turning on my car and leaving it run for 10 min or so in the mornings before I drive it.
Is that bad??
Jump to top gam3cock is offline   Reply With Quote
Old Fri, Jan-12-2018, 07:13:07 PM   #33
Is that bad??
Yes. Stop doing that.
Old Fri, Jan-12-2018, 07:25:40 PM   #34
S54 Z3Ms, with their 7600rpm redlines but identical hardware, do not suffer the same bearing wear as our 8000rpm S54s.
Actually they seem to. BMW just didn't do the recall on them
Old Fri, Jan-12-2018, 07:26:17 PM   #35
Recall was due to the production defect, not wear, no?
Old Fri, Jan-12-2018, 07:26:48 PM   #36
rovert604
rovert604's Avatar
Is that bad??
Just drive it lightly and gingerly to warm it up. I think i read that idling doesnít allow oil to get into all places of. Cold engine because there is not enough oil pressure to splash all over. Because the engine runs cold for longer the rich fuel mixture will prematurely wear out and contaminate the catalytic converters as they canít warm up fast enough to do their job. Once you drive off you think you can drive like a madman forgetting the fact that every other moving part of the car hasnít been warmed up yet like your transmission/diff fluid which is still cold.
The OEM RPM warmup light setting sets the lights really low for oil temp. It does follow the oil temp but BMW coded the lights to start turning off at 10įC to a max of 60įC. I custom set mine (from MSS5x Binary Mod Tool) to start turning off at 30įC and end at 80įC.
--Trevor in 604--
Vancouver, BC, Canada
Old Fri, Jan-12-2018, 07:36:27 PM   #37
SliM3
SliM3's Avatar
Originally Posted by mrgizmo04 View Post
Per what Ian said, I think there is some oil starvation going on at higher rpms on these engines, so the closer and the more frequently you want to play around 8k rpm (or even above), the faster your bearings will wear/fail.
I havenít experienced any starvation or cavitation with a 9k redline & stock pump. Plus, VANOS would lag big time if this happened at high rpm; Not to mention possible valve clipping.
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Fri, Jan-12-2018, 07:44:05 PM   #38
Bmw elected not to do it on the Z3M, using the lower rpm limit as a justification. But they still go through them relatively quickly
Old Fri, Jan-12-2018, 08:01:51 PM   #39
mrgizmo04
mrgizmo04's Avatar
I think (and this is a hypothesis) that at some point you hit volumetric flow capacity of the runners and the pump at the pressures pump/lubrication system can support. With higher crank speeds you would run into that max. You obviously don't run the car at 8 or 9k all day, but you do get longer times up there in higher gears and at higher vehicle speeds. Track cars def wear them out quicker. What exactly causes it, that is unknown.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Jan-12-2018, 08:37:40 PM   #40
grannyknot
Reputation: 0 grannyknot is on a distinguished road
Since the s54 bearing wear seems to track with high RPM usage and not with cold starts, I'm going to skip the pre oiler. Feels like a solution to a non problem, to me.
Strong proponent of KISS, here.
I agree completely, a pre oiler is overkill for most engines, just throwing it out there as another option for Doogan.
Jump to top grannyknot is offline   Reply With Quote
Discussing Mitigating Cold Start Wear in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
