Old Thu, Jan-11-2018, 04:38:52 PM   #1
TheDoogan
Forward Loaded
TheDoogan's Avatar
Reputation: 0 TheDoogan is on a distinguished road
Default Mitigating Cold Start Wear
Hey guys,
Are there any strategies to mitigating cold start wear? I'll admit that I'm a little confused about why it's so destructive; isn't the crank shaft completely submerged in the oil reservoir at all times, but especially deeply when the engine is turned off?
I'm having new rod bearings installed right now, as well as a cam shaft, rockers etc - WHAT oil should I use from here on out?
My car was owned by two people previously; a woman who owned it until 33k miles (CarFax shows zero recorded dealer services), after that, it had regular oil changes by a friend of mine until I bought it at 52k.
I'm not sure what the existing bearings look like; they haven't removed them yet. But I'd love any tips you guys have. I want to take very good care of the engine now, and only make INTENTIONAL withdrawals.
Thanks!
Dr. DGN
PhD, honorary doctorate from the University of Hard Knocks
2006 E46 M3, 6MT, Convertible, Black/Black - 72k miles
60k mile Service II, Evolve CSL Intake w/Alpha-N tune, Schrick CSL Cam, Active Autowerke Catless Headers, Section 1 High-flow cats & Section 3.
Jump to top TheDoogan is offline   Reply With Quote
Old Thu, Jan-11-2018, 05:16:54 PM   #2
skylinekin
skylinekin's Avatar
Reputation: 0 skylinekin is on a distinguished road
Default Re: Mitigating Cold Start Wear
Originally Posted by TheDoogan View Post
Hey guys,
Thanks!
Dr. DGN
No, the crankshaft is not submerged in oil. How cold of weather do you use the vehicle in?
Best practice is to start the car and begin driving at a conservative pace until the engine oil is warmed. Idling to warm up the engine or starting and immediately shutting off the car causes unnecessary wear on the engine.
I’m sure someone else will chime in on the technical stuff.
Jump to top skylinekin is offline   Reply With Quote
Old Thu, Jan-11-2018, 05:28:17 PM   #3
icecream
Registered Apples
icecream's Avatar
Hey guys,
Thanks!
Dr. DGN
As he ^ said, it does not sit in oil, it would froth up quickly and be ineffective. I think you're overcomplicating it. Nothing will make the engine last forever and these already last a long time with 10w60 and regular changes. Don't race the motor when cold is about all you can do. If you are in subzero weather, consider a 0w-40. If you want to take it another step further don't rev past 7k but that would be idiotic.
Old Thu, Jan-11-2018, 05:33:52 PM   #4
Drewster
Drewster's Avatar
It's definitely a question of how cold your climate really is (assuming the car isn't garaged).
Otherwise, let it run until the idle is stable, and then baby it until your oil gets close to 210F
If you're driving the thing in sub-zero temps a lot, you may want to change to a different weight for the winter and look into block heaters, etc.
Old Thu, Jan-11-2018, 05:57:27 PM   #5
SliM3
SliM3's Avatar
I plan on picking up an Insta-Lube Engine Pre-Lube Kit. Might be an option for you to consider as well.
Old Thu, Jan-11-2018, 06:47:23 PM   #6
rovert604
rovert604's Avatar
Because so many people use Liqui Molyís 10w60, Iíve started using their Ceratec which says its bonding abilities lasts for approx 30K miles. I also just dump their MOS2 in the crankcase in between refreshing Ceratec.
My multiple Blackstone oil analysis have come back with clean results showing little wear so Iím happy about that!
--Trevor in 604--
Vancouver, BC, Canada
Old Thu, Jan-11-2018, 06:54:07 PM   #7
Since you're not tracking, you'd like be fine with a 0w-40, which would significantly improve engine cold start wear.
Or you could get an engine block heater and heat your oil between uses.
Or just not worry about it and change the rod bearings as oil analysis dictates, which really isn't that often at all-- your car has been roving the earth for 12 years and if just now having them replaced for the first time. Will you even own it 12 years from now?
I'd skip any/all additives.
The crank is never submerged in oil.
Old Thu, Jan-11-2018, 07:18:19 PM   #8
Jaap
Reputation: 0 Jaap is on a distinguished road
Hey guys,
... why it's so destructive; isn't the crank shaft completely submerged in the oil reservoir at all times, but especially deeply when the engine is turned off?
No the crank shaft hangs above the oil and if it touches the oil anywhere (when overfilled) the forces due to slapping the oil every time would not be good for the engine.
Cold start wear is because:
- Block is cold, some items (like pistons) heat up fast, others slow. This changes the tolerances.
- Oil pressure is high, oil flow is low. Oil may not have reached (and stuck to) all nooks and crannies yet.
Jump to top Jaap is offline   Reply With Quote
Old Thu, Jan-11-2018, 08:26:33 PM   #9
TheDoogan
Forward Loaded
TheDoogan's Avatar
Excellent. Okay, good points all around you guys, and crazy enough, I've always pictured the crank being submerged when off/settled, and then the oil level falling just below it as the pump began circulating. It's comical what ideas can form in the head, absent of actual knowledge, I suppose.
Okay; I DO garage my car, and it never sits below about 38 degrees (I keep a small heater barely turned on all winter long), but certainly sometimes it'll get down to 5-10 degrees F when sitting outside a restaurant or my office, if it was a clear day and I drove it.
Ian has a good point about them lasting 12 years, with two fairly inexperienced and ignorant owners (who really get pardons, because they can't be expected to dive so deeply into this stuff, I suppose). You are right: there's a very small chance that I'll own this car in 12 years. Even though I can't imagine what it will look like when I get rid of it. That's a sad thought!
Okay, I'll run the 0 weight for the rest of the winter, and I'll change to the 10w-60 when the weather begins warming up.
Do I surmise correctly that the disadvantage of 0 weight for track use is that it gets too hot?
I'll also look at a block heater; gadgets and OCD-level preparation always sounds exciting.
Old Thu, Jan-11-2018, 09:39:00 PM   #10
whips333
whips333's Avatar
Honestly, unless you live in Alaska or somewhere where it's 0-10 degrees F for 2 straight months I'll just stick with the 10w-60. I live in new England and just got my blackstone results back yesterday and everything is normal. The key is your right foot and how patient you are to let your baby warm up before you give her the beans. I usually wait until my needle is close to 210 before I even think about going over 3k. Usually that's about 18-20 mins of driving like a grandma which I don't mind.
Discussing Mitigating Cold Start Wear in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
