Old Tue, Jan-09-2018, 05:44:43 PM   #11
SpeedDemon_M3
Reputation: 0 SpeedDemon_M3 is on a distinguished road
Default Re: SMG Trouble
The car has 121,xxx miles. As far as the clutch being original, I'm not to sure on that. My guess is yes. Reason being many of the parts I've replaced on the car have been OE BMW parts.
Jump to top SpeedDemon_M3 is offline   Reply With Quote
Old Tue, Jan-09-2018, 05:49:06 PM   #12
Joshe46
Joshe46's Avatar
Thats kind of early for a clutch on an smg to fail, however it depends on driving style. Id let others chime in. Could be GPS but sounds like a clutch problem to me.
Jump to top Joshe46 is offline   Reply With Quote
Old Tue, Jan-09-2018, 06:30:49 PM   #13
SpeedDemon_M3
I'd rather have the clutch go out, instead of the SMG pump. In which case I would just opt for a 6MT swap.
Old Tue, Jan-09-2018, 07:06:13 PM   #14
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
i would first read the fault codes. you'll need something like INPA to read the bmw specific fault codes for the smg. standard ob2 reader will not work.
you can look up your fault codes here:
Tischer aka GetBmwParts
Old Tue, Jan-09-2018, 07:21:43 PM   #15
Joshe46
Joshe46's Avatar
No doubt. That being said if it is clutch, stop driving it or else it will leave you deserted eventually when it truly fails.
Old Tue, Jan-09-2018, 09:11:17 PM   #16
MrVond
The Phanto///M
Reputation: 0 MrVond is on a distinguished road
i have the same problem from 2>3, 4>3
comp spring is probly broken
GPS might be on the way out as well
///M
Jump to top MrVond is offline   Reply With Quote
Old Wed, Jan-10-2018, 12:59:19 AM   #17
Joshe46
Joshe46's Avatar
Comp spring issues only cause a delayed shift, not so much a complete fail at a gear change no? Im sure my comp springs are weak as my 1st to 2nd drags sometimes, or it could be because I shift like a granny sometimes
Old Wed, Jan-10-2018, 07:04:38 PM   #18
whips333
whips333's Avatar
Something similar to this happened to me yrs ago. I can't go into detail right now because I'm at work but long story short I had to replace my clutch, flywheel, throw out bearing etc.
Old Thu, Jan-11-2018, 12:28:52 AM   #19
cagan1984
Reputation: 0 cagan1984 is on a distinguished road
I think it might be the clutch as mentioned...I have never heard an smg issue while getting kicked in 2nd gear
Jump to top cagan1984 is offline   Reply With Quote
Old Thu, Jan-11-2018, 09:39:50 PM   #20
cagan1984
Were you able to read some codes?
Sent from my BLN-L24 using Tapatalk
help and advice, smg e46 problem m3, smg gear light
Discussing SMG Trouble in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
