Old Sat, Jan-06-2018, 05:20:36 PM   #1
lemoose
lemoose's Avatar
Reputation: 0 lemoose is on a distinguished road
Default Stuttering Acceleration
When getting on the gas hard at RPMs where you can typically break traction, the car stutters/bucks HARD- as if the fuel is completely cut off for a fraction of a second. Then the gas kicks again and the cycle repeats itself until it smooths out around 5-6k. Same thing happens in second gear (albeit in a narrower RPM range) but never in N or any other forward gear
The issue became obvious last night. However, I had noticed in recent days the car would buck a bit when I got on the accelerator. I thought it was just my foot coming off the accelerator as I got pushed back into my seat.
-Spark Plugs and ignition coils have been replaced no more than 6 months ago
-no OBD codes
-tried switching to Alpha-N and the issue persists (so I assume not MAF related)
-Issue persists with traction control disabled
I tried reading engine errors through INPA (screenshot). But my INPA is in german (Mikes Easy BMW Tools Package) so I need some help translating as google search hasn't been much help.
Anyone have any ideas? All input is much appreciated.
Jump to top lemoose is offline   Reply With Quote
Old Sat, Jan-06-2018, 05:23:57 PM   #2
Drewster
Drewster's Avatar
Default Re: Stuttering Acceleration
There is no screenshot attached.
Old Sat, Jan-06-2018, 05:28:35 PM   #3
lemoose
lemoose's Avatar
I put it in using insert image but for some reason it doesnt post. I hyperlinked it now though. Thanks!
Old Sat, Jan-06-2018, 05:34:57 PM   #4
Drewster
Drewster's Avatar
http://www.m3forum.net/m3forum/showthread.php?t=457239
Looks like either clutch switch or gear position sensor issue
Old Sun, Jan-07-2018, 04:45:21 AM   #5
mrgizmo04
mrgizmo04's Avatar
Dying fuel pump or fuel starvation?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Jan-13-2018, 12:46:49 PM   #6
cagan1984
Reputation: 0 cagan1984 is on a distinguished road
Why did you think so or how would this effect in your opinion?
Sent from my BLN-L24 using Tapatalk
Jump to top cagan1984 is offline   Reply With Quote
Old Sat, Jan-13-2018, 12:48:30 PM   #7
cagan1984
I just installed a cae shifter and swapped from smg to mt. After that the car started doing similar thing for me as well.
So maybe the transmission related parts have to do something with this
Is your car mt or smg btw?
Discussing Stuttering Acceleration in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
