Old Fri, Jan-05-2018, 07:33:50 PM   #1
erickrayos
Default coolant leak
Hey guys!
I recently encountered coolant leak and from what I can see it was coming somewhere under the pump from the trace amounts of coolant there and it kinda goes on the crank pulley and getting flinged upwards onto my intake box to the right.
So thinking maybe the O-rings and gaskets are at fault I replaced them yesterday, the thermostat O-ring was bad so I thought "this is most likely the cause!" replaced that, and waterpump gasket and the other 4 O-rings from the black pipe and the one behind the thermostat.
bled it and no leaks that I can see, but after driving it I noticed there's small trace amounts of coolant again on my airbox. I cleaned the area under the waterpump when I had it off and so far I can't see any on there right now, maybe because it hasn't been that long I guess and the amount that was there before may be due to it having leak for quite a while.
Any suggestion what to check next? I checked the water pump and it seems to spin as good as when it was new, I tried google to see if water pump on e46 M3 can lean and all that comes up are from the other 3 series pumps and I didn't see any specific for M3.
And if you guys think it is the pump itself, is rein or saleri good to go? I've used this pump I have for 2yrs now as a emergency part to use brand was Beck arnley.
Jump to top erickrayos is online now   Reply With Quote
Old Fri, Jan-05-2018, 09:33:36 PM   #2
bigjae1976
Default Re: coolant leak
Id make sure the 2 water pipes are seated correctly. Did you lubricate the O-ring with coolant before reinstalling the water pump & t-stat?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Fri, Jan-05-2018, 10:10:13 PM   #3
erickrayos
Yes they seat properly and yes I lubricated them with coolant before putting them in.
Old Sat, Jan-06-2018, 12:47:47 AM   #4
bigjae1976
Coolant hose not tight?
Only other thing I can think of is the water pump is leaking around the shaft. There is a seal which allows the shaft to turn and not leak.
Old Sat, Jan-06-2018, 12:55:51 AM   #5
erickrayos
Ok, I'll try to see if the base auto hobby shop got the right pressure tester to check that out. if not I'll probably just buy a new pump and hopefully that fixes it. the leak is very minimal that it doesn't really affect the cooling, I just have to top it off. last time I had the coolant drained was during the header install and light came on after about 3 weeks.
Old Sat, Jan-06-2018, 02:43:42 AM   #6
mrgizmo04
mrgizmo04's Avatar
What about the water pump gasket itself? I think some of them are paper/cardboard that could leak over time vs a metal one from BMW?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Jan-06-2018, 07:15:47 AM   #7
erickrayos
replaced that as well, as I said I replaced every O-ring and gasket that can be replaced. I got the metal one.
Old Sun, Jan-07-2018, 06:44:00 PM   #8
Speed Monkey
Bananas, Just Bananas
Speed Monkey's Avatar
You're in San Diego? Make it easy on yourself and just take it to Forum Member KAIV. He's very well known amongst the community here. Just contact him to get your problem fixed.
Jump to top Speed Monkey is offline   Reply With Quote
Old Sun, Jan-07-2018, 09:19:10 PM   #9
erickrayos
Yeah I am in San diego, I'm really guessing its the water pump tho, I mean every o-ring replaced and the pump gasket replaced and only leaks when the car is on (start up is the most obvious as I can see the coolant getting flinged by the belt/pulley? to my airbox).
just sitting there doesn't show any leak that we can see on my borescope. Of course I can't really use borescope when car is idling and we don't have a radiator pressure tester that fits. Imma just order the pump and see if it still leaks after installing it.
Old Sun, Jan-07-2018, 09:37:13 PM   #10
Speed Monkey
About your ride, if it's your only car and you use it for your livelihood, meaning getting yourself to and from work everyday and its got the original cooling system components in it, it's time to replace the system. If you've already replaced all the main parts like the radiator, hoses, fan clutch, the plastic fan itself along with all the idlers, pulleys, and belts, please ignore, of course! But if not man, we got what's basically a 15 yr old car on our hands and those parts listed above are far from lifetime parts ya know. Anyways, I'm just interested in keeping you trouble free and happy. If it looks like soap box, sorry man, that's far from the intention. Lastly, take it to KAIV! He's a super good dude; he's done lots of maint. on my sled. Happy New Yr!
Discussing coolant leak in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
