Old Fri, Jan-12-2018, 03:18:32 AM   #101
icecream
Registered Apples
icecream's Avatar
Default Re: Obioban's Avin Avant 3 thread (eventually DIY to delete all stereo modules/harnes
Originally Posted by scoopy128 View Post
Just a question guys, if u have the nav package etc and you are removing the cd and nav system do you have to recode it and remove the nav package?
I don't see why bothering. I did not code mine out.
Unless you don't want DIS catching any errors but that doesn't affect anything.
Old Fri, Jan-12-2018, 04:21:41 AM   #102
You shouldn't have to recode anything. There is a function in the climate control panel that apparently has something to do with the navigation, but I suspect it might just be a lighting adjustment for its position in nav cars.
Otherwise as far as I can tell, the only other module that cares about the navigation system is the instrument cluster. One function is the speed limit thing which you can still set via the Avin. The other function is the distance to the next turn, which I guess won't work anymore (but leaving it enabled shouldn't hurt anything).
Old Fri, Jan-12-2018, 06:40:40 AM   #103
scoopy128
Reputation: 0 scoopy128 is on a distinguished road
Oh ok thanks reason i ask because when im using my ista if i dont see the navigation in my radios menu it takes like 15 mins to scan my car and read all the modules and it will show a nav error. But sometimes if my nav is working it can finish the scan in just like 2 mins hehe
Jump to top scoopy128 is online now   Reply With Quote
Old Fri, Jan-12-2018, 12:17:11 PM   #104
If you remove the nav option code, it'll just look for the standard radio instead which will give the same issue.
Old Fri, Jan-12-2018, 01:25:31 PM   #105
scoopy128
Oh ok thanks hopefully i will be able to also install then tomorrow. So now you guys are experiencing what problems? Bluetooth disconnects once in awhile? (U guys use bluetooth for music or for calls?)
Old Sat, Jan-13-2018, 02:05:25 AM   #106
If the nav unit initiates the BT connection, it seems to suddenly disconnect around 30 minutes into the drive. If I initiate the connection from my phone, it works fine seemingly indefinitely. Not sure if the bug is with the Avin or my phone on that one. I haven't hooked up the microphone yet, so I haven't tested phone calls
On another note, I went ahead and wired up my factory GPS antenna (which I had because my car came with BMW Assist) to the Avin - it works, and the signal is pretty strong (getting a fix on 10 satellites in my garage). As mentioned before, the GPS connector for the BMW Assist module is different than what navigation cars got, so the adapter Avin sells won't work.
Old Sat, Jan-13-2018, 02:12:41 AM   #107
icecream
Registered Apples
icecream's Avatar
Is Ista another name for DIS? If it has the same interface you can scan only the modules you want by first selecting no to running tests when it prompts you and deselecting everything before scanning or "testing modules". My terminology might be off but if it's the same, you know what I mean.
Old Sat, Jan-13-2018, 02:24:58 AM   #108
Ista is the latest diagnostic suite from BMW. It wants to attempt finding all the modules the car has before it lets you do much of anything else.
Old Sat, Jan-13-2018, 02:52:51 AM   #109
icecream
Registered Apples
icecream's Avatar
Ah, got it. I thought he meant he was waiting for it to scan for errors.
Old Sat, Jan-13-2018, 12:15:32 PM   #110
scoopy128
Only with bmw assist that you have a gps antenna? I have a block box thingy in my windshield and a mircrophpne in the pillar. The owner told me he didnt add that they came out from the dealer with that
Discussing Obioban's Avin Avant 3 thread (eventually DIY to delete all stereo modules/harness) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
