Old Thu, Jan-11-2018, 09:17:17 PM   #51
maynard423
maynard423's Avatar
Reputation: 0 maynard423 is on a distinguished road
Default Re: Clutch and Flywheel Recommendations
Think I should replace the guide tube. It has some pretty deep scores on it?
05 M3 6MT Carbon Black Vert
Jump to top maynard423 is offline   Reply With Quote
Old Thu, Jan-11-2018, 11:29:18 PM   #52
mleveroni
Reputation: 0 mleveroni is on a distinguished road
I ran a JB aluminum flywheel with South Bend's stage 2 daily kit with a sprung hub disk. Take my word and steer clear away from this setup. I'm planning on making a separate thread once the situation is sorted.
2002 M3 Carbon Black 6MT
ARP Headstuds|ARP Rod Bolts|Beisan Vanos|Topspeed Exhaust|AR20's|Ebay Headers|Turner Subframe Plates|ZCP Rims|Custom Rear Strut Bar|AKG Bushings|ST XTA Coilovers|Clutchmasters FX300 Clutch/Aluminum Flywheel|RK Tune
Jump to top mleveroni is offline   Reply With Quote
Old Fri, Jan-12-2018, 12:43:05 AM   #53
bigjae1976
Was it the flywheel, clutch or both?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Fri, Jan-12-2018, 01:40:57 AM   #54
maynard423
maynard423's Avatar
Default Clutch and Flywheel Recommendations
I just weighed the DKM LTW Steel Single Mass. It weighed 23.2 lbs. My OE DM weighed 24.9 lbs. I guess they were shooting for a 2 lb reduction from OE.
Old Fri, Jan-12-2018, 02:13:13 AM   #55
mleveroni
The problem was with the clutch kit. I think the flywheel, being single mass and lighter, accelerated the issue.
Old Fri, Jan-12-2018, 03:49:15 AM   #56
mrgizmo04
mrgizmo04's Avatar
Yes, you might as well.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Thu, Mar-01-2018, 08:39:22 PM   #57
E46er4Life
Reputation: 0 E46er4Life is on a distinguished road
I bought the DKM kit from ECS. I did an open box review of it that will be posted on YouTube shortly. High quality kit in appearance. It comes with a SACHS throw out bearing. BMW uses them as an OE supplier for those who don’t know. I actually had purchased an BMW bearing and sent it back. They were identical. All the numbers matches and you can see where they dremeled off the BMW markings.
So what's your take on the DKM kit after a couple months? Did you go with stage 1, 2, or 3?
Jump to top E46er4Life is offline   Reply With Quote
Old Thu, Mar-01-2018, 08:42:02 PM   #58
maynard423
maynard423's Avatar
Stage 1. Havenít driven it yet. Have the rear sub frame out now. The transmission is in. Clutch pedal is a bit stiffer and it appears as though itís going to release quite low to floor. Iím not sure I have all the air bled out though.
Discussing Clutch and Flywheel Recommendations in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
