Old Thu, Dec-14-2017, 01:38:29 PM   #11
Default Re: Clutch and Flywheel Recommendations
There is no reliability concern with any of the stock components. If reliability is your primary concern, moving off them is a step in the wrong direction.
If you want lighter/better feel, there are better options out there. So far every one I've experienced has come with the side effect of noise, which has made them a non starter for me.
Old Thu, Dec-14-2017, 01:54:36 PM   #12
HassanEido
HassanEido's Avatar
Lebanon
This is one area you should leave alone.
Stock clutch and flywheel, and only use bmw OE slave master cylinders and throw out bearings.
Rock solid setup.
Mods:
Modified stock airbox,afe plastic intake elbow Afe prodry drop in, electric fan conversion,SSV2 catless headers, custom 2.5" dual sec1, custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3,tms pulleys,Cat Cams 280 272, custom dyno tune, csl box pending
357.7 whp 283.5 wtq
Old Thu, Dec-14-2017, 02:31:22 PM   #13
robgill
I'd rather be at the track.
robgill's Avatar
Reputation: 0 robgill is on a distinguished road
Originally Posted by rpearl555 View Post
Does the steel flywheel not rattle when compared to aluminum? I thought single mass fly wheels chatter from being single and not dual!
I donít get any rattle/chatter, honestly no negative impact. On the positive side the engine revs a little faster. I notice it most on the track when downshifting.
My '02 E46M Build Thread
Jump to top robgill is offline   Reply With Quote
Old Thu, Dec-14-2017, 03:27:50 PM   #14
Originally Posted by robgill View Post
I've got the Rogue Engineering stage 1 clutch with single mass steel flywheel. Lighter than stock (14lbs) without the chatter of an aluminum wheel. Pretty happy with it so far on street and track.
I'd like to drive a car with the RE Steel flywheel. I just drove a car to CA with Rouge's Alu flywheel, and it was super obnoxious. The cars owner is going back to stock after that experience
Old Thu, Dec-14-2017, 04:05:51 PM   #15
bigjae1976
Depends on the condition of your tranny I guess. If you look at the JB flywheel, it makes sense why it would rattle. Itís essentially a block of aluminum. It does rattle.
Not sure how a clutch or pressure plate would rattle?
Still think stock is the way to go.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Thu, Dec-14-2017, 04:11:55 PM   #16
mikerob
Reputation: 0 mikerob is on a distinguished road
When installing a single mass flywheel, as long as you install the proper clutch disc that has a center sprung hub, you should not experience abnormal transmission rattle. On both my E36 (s50 engine) and E30 (stock engine), I converted to steel single mass flywheels with a center sprung disc, without any abnormal transmission noise.
I have no experience converting an E46 M3 (mine is still a stock), but would be very surprised if it doesn't behave the same as the E30 and E36 conversions i have done over the years.
Now, I have driven friend's cars (E36) that converted to a lightweight aluminum single mass flywheel and used the stock (non-sprung) disc. Yes, these cars rattle - a lot!
Mike
Cary, NC
Current Ride
- 2006 BMW M3 Cabriolet, Euro Headers and Cats, SuperSprint Sport Exhaust, 3.91 Gears, TTFS Tune, Mason Eng Clutch Pedal
Past Ride
- 1991 BMW 325i (E30) Cabriolet, Stock European Exhaust (w/o Cat), Bilstein Shocks and Struts, Hella Ecode Headlights
- 2000 BMW 323i (E46) Sport Touring, 330i Front Calipers & Rotors, Bilstein Shocks and Struts, SAP Delete, Sirius Receiver, HID/Projector Headlights.
- 1994 BMW 325is (E36) S50 Engine, Schrick Cams, Custom Chip, 3.46:1 LSD Final Drive, 330i Front Calipers & Rotors, (Lots of Modifications)
- 1987 BMW 325is (E30) European ECU and Camshaft, M3 Suspension, Headers with Custom Exhaust.
Jump to top mikerob is offline   Reply With Quote
Old Thu, Dec-14-2017, 04:18:35 PM   #17
bigjae1976
The problem with the E46 M3 is I donít think there are many aftermarket sprung JB clutch options???
Old Thu, Dec-14-2017, 04:33:45 PM   #18
mikerob
I am afraid that without installing the center sprung clutch disc, you will loose ALL crankshaft pulse dampening...To me, this is not wise retrofit...
Mike
Cary, NC
Current Ride
Past Ride
Old Thu, Dec-14-2017, 04:51:13 PM   #19
mikerob
Here is a kit from ECS tuning that uses an aluminum flywheel with a center sprung disc...Maybe someone makes a similar kit for a steel single mass flywheel?
Again, the key is to use a center sprung disc when retrofitting to SMF to retain the dampening properties of the original DMF flywheel. I feel this important point does not get emphasized enough in many of the forums posts I have read throughout my years of wrenching on BMWs.
https://www.ecstuning.com/b-assemble...20-010s-s874g/
Mike
Cary, NC
Current Ride
Past Ride
Old Thu, Dec-14-2017, 05:51:36 PM   #20
bigjae1976
Many engine builders donít like LTW flywheels and crank dampers although there are varying opinions. What Iíve been told is you can do the damper or flywheel but not both.
Discussing Clutch and Flywheel Recommendations in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
