Old Tue, Jan-09-2018, 01:28:53 AM   #181
grke36m3
Reputation: 0 grke36m3 is on a distinguished road
Default Re: Turner's new monoball FCABs
Originally Posted by STAATS View Post
They already have:
https://www.turnermotorsport.com/p-1...6-e46-z4-pair/
it is just an unsealed monoball so is more for race cars.
The general consensus on road going monoball RTAB for these cars (price vs quality) is the SyncroDesign Works unit:
https://syncrodesignworks.com/products/rtabs
Although it should be noted for full disclosure that Dinan also do one that has amazing reviews but is considered very expensive and I believe there is another company... I want to say Fall Line Motorsport? that does one also for this car.
Oh I see. Thought they would make a sealed one. Thanks
Jump to top grke36m3 is offline   Reply With Quote
Old Tue, Jan-09-2018, 03:14:37 AM   #182
I really like my SDW sealed sphericals for RTABs
/// 2004 SilberGrau M3 ∑ Coupe ∑ 6MT ∑ slicktop ∑ manual seats ∑ zero options ∑ JOURNAL
-NA S54-
∑Evolve-R Alpha N ∑ Evolve CSL CF Airbox ∑ Eventuri Scoop ∑ Supersprint V1 stepped 63mm ∑ SS V1 S pipe 63mm + 200 cell HFC ∑ OE sect 2 60mm ∑ SS Sport 60mm
∑Besian ∑ RE pullies/fan delete ∑ WPC rod bearings ∑ GroundControl S/A (Koni/Eibach 440/550) + tall RSMs ∑ TMS Camber & Subframe plates ∑ SPC Adj alloy rear camber arms
∑RE Trans Mounts ∑ AKG poly SUB/DIFF 95a ∑ SDW RTAB ∑ Weighted ///M knob + UUC DSSR + delrin carrier bush ∑ OE CSL trunk ∑ APEX 75mm Studs
∑Sportline 8S 18"x8.5/9.5" ∑ MPSS 245/275 ∑ Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF ∑ CM brackets & ss/teflon lines
∑Pioneer DEH-80PRS ∑ Eclipse PA5422 ∑ CDT HD-6 + WS-100i ∑ CDT EX-530 ∑ 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 ∑ PPI 1600.4 ∑ CDT HD-6 + HD-100 ∑ CDT EX-530 ∑ DVC 10"
Old Tue, Jan-09-2018, 03:38:46 AM   #183
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
They already have:
I have the FallLine Motorsports Monoball rtab's, quality pieces but not as pricey as Dinan. When I was doing my research it was either FL or SDW for the rtab's.
Build///Journal
IG: @Khan_Art_
Old Fri, Jan-12-2018, 02:02:50 AM   #184
SQ13
I got my FCABs installed 1Ė2 weeks ago. I had a little difficulty lining up two holes on the OE fcab retainer for the bolts; I had pushed the bushings in as far as they would go by hand but right side took some time to line up correctly. It took a few blows with a mallet to push them in a bit more to get holes lined up. The last shop to replace my FCABs ****ed up the control arm a bit, but I donít know if their incompetence contributed to install difficulty.
There is increased feedback through the wheel. You can feel the road imperfections more, and it feels more direct than OE. But itís not annoying or anything and would be fine for a car that gets tracked often (street car too imo). Will see how it feels at COTA on the 28th.
Big thanks to The Fly for getting these to me quickly. This was my second transaction with him, first was for OE FCABs.
Old Fri, Jan-12-2018, 04:49:14 AM   #185
PhanTran
PhanTran's Avatar
Reputation: 0 PhanTran is on a distinguished road
I changed out my control arms yesterday and took a chance on the fitment of the Turner lollipops. I placed each fcab over the mounting dowels to make sure theyd fit correctly; the driver's side slid on fine, the passenger side was a bit harder but I found that it was a little dirty. So i scraped off all of the gunk buildup with some sandpaper and it fit on well. One thing of note that I would have to suggest to anyone changing out control arms: a mini sledgehammer is a MUST. I was whacking the ball joint knuckles for hours with regular sized hammers and nothing happened. Had my friend drop by with his mini sledge and I whacked that ball joint out with ease! Anyway, I still need to drive the car about and get a better impression on the monoballs, but I do notice a difference and it's hard to put into words what exactly I'm feeling... The word "fun" comes to mind.
Sent from my SM-N950U1 using Tapatalk
Jump to top PhanTran is offline   Reply With Quote
Old Fri, Jan-12-2018, 01:04:11 PM   #186
The Fly
Reputation: 0 The Fly is on a distinguished road
Thanks for the kind words! Iíve got two more pairs ready to go...
Need M3 FCABs? I sell them pre-pressed with new OE bushings or with aftermarket poly...
http://www.m3forum.net/m3forum/showt...post1065958863
http://www.m3forum.net/m3forum/showthread.php?t=446004
Jump to top The Fly is offline   Reply With Quote
Old Sun, Jan-21-2018, 08:11:01 PM   #187
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
So I noticed something yesterday, might be totally normal but thought I mention for piece of mind.
Let me state no other changes were made to the car especially ride height and tire size. I noticed when I have the steering turned all the way to lock in either direction the front tire is almost barely if not just slightly touching the fender liner. I'm almost sure it did not do this before. I'm thinking this is due to extra travel provided by the bushings articulating in the housings? I really want to say it wasn't like this and it's due to the bushings.
Build///Journal
IG: @Khan_Art_
Old Thu, Feb-08-2018, 03:03:35 PM   #188
The Fly
bump!
Old Tue, Mar-13-2018, 03:22:28 PM   #189
The Fly
One set sold, one more available...
Old Sun, Mar-25-2018, 05:16:26 AM   #190
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
Any other feedback on these? Goin to order a set in the next week or so.
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@_Frank_Stone_
Jump to top OneFastSicilian is offline   Reply With Quote
Discussing Turner's new monoball FCABs in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
