Old Fri, Nov-04-2016, 06:40:28 PM   #21
mrgicm
mrgicm's Avatar
Reputation: 0 mrgicm is on a distinguished road
Croatia
Default Re: M4 Brakes on E46 M3?
So as it appears my friend has done on a couple of e46 and today I spoke with the owner of the one from the pictures and he said its running without problems and he has been on the Nurburgring and done several track days and the car stops like crazy with no unnecessary abs intervention and a great brake pedal feedback.
The front callipers go on pretty straightforward with just a simple adapter has to be machined.
The rear are a bit tricky as you have to modify the rear calliper slightley on the machine in order to have perfect aligment of the pads to the discs.
Here are photos from 2 sets being made to fir the E46 M3.
Photos are from my local company Milletech that build awsome exhaust systems for some top cars.
Jump to top mrgicm is offline   Reply With Quote
Old Fri, Nov-04-2016, 06:50:47 PM   #22
zippity
Reputation: 0 zippity is on a distinguished road
I would also like to hear the legitimate numbers...but from an aesthetic point of view...looks awesome.
Jump to top zippity is offline   Reply With Quote
Old Sat, Nov-05-2016, 01:22:30 AM   #23
LINDW4LL
LINDW4LL's Avatar
Reputation: 0 LINDW4LL is on a distinguished road
Can you give us the numbers? Would be good to add it to the database, if it's actually better.
The F8x non-CCB calipers use 40mm pistons. This gives a piston area calculation of 2513.28mm^3 versus 2827.43mm^3 for our stock caliper.
(Obviously aware that there is more to brake bias than piston area alone, but just giving a start).
2003 ///M3
| Stahlgrau | FABSPEED Headers | Section 2 EVC | buildjournal |Turner MS Sway Bars | Bilstein | Pilot Sport 4S | Porterfield R4-S | OE LED Tails | M-Track DSC |
Jump to top LINDW4LL is offline   Reply With Quote
Old Sat, Nov-05-2016, 04:52:23 AM   #24
silvergray545
silvergray545's Avatar
Are we assuming F8x rotors will be used for the swap?
2004 BMW M3 6MT - TiAg/Gray
2016 BMW M3 ZCP 6MT - AW/SO
2014 VW GLI 6MT - Black/Black
E46 M3 Build Journal
Old Sat, Nov-05-2016, 07:32:14 AM   #25
mrgicm
mrgicm's Avatar
Croatia
Yes ofcourse. I am also thinking of trying oem bmw performance track day pad for those callipers.
Old Sat, Nov-05-2016, 02:27:23 PM   #26
nasieg
nasieg's Avatar
Looks pretty good. I would also be curious to know how what the brake bias is with these?
Nice milling job on the brackets. The only thing I don't necessarily like, is that the front caliper had to be re positioned upwards. I totally understand why that was necessary, as I have done the exact same thing on other BBK conversions on the rear brackets. I don't think it would be a deal breaker if everything else was good, but ascetically I don't love that part of it.
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Sportline CS8's, SG CSL Diffuser, OEM CSL Trunk
Jump to top nasieg is offline   Reply With Quote
Old Sun, Apr-30-2017, 11:07:47 PM   #27
M3 dude
hilarious how people ark up and pan out old mate for trying a different combo.
i'll bet the bloke who first tried the 996 caliper combo got reamed too...
Old Tue, May-02-2017, 03:11:49 AM   #28
802Hoop
is in the hizouse
802Hoop's Avatar
Reputation: 0 802Hoop is on a distinguished road
I don't see anyone getting "reamed" here. So far seems to be a fairly civilized and honest discussion. I think good feedback comes in many forms, but nobody has made any attack on the op.
"I don't care how much you upgrade your car, if you don't get your ass out on the track, your money is going to waste and your modifications mean nothing."
CCW Classics, Autosolutions 40%, Bimmerworld brake bushings, PFC DD rotors, PFC 11 pads, SS lines, Dinan intake/MAF, Dinan Stg 3 Software, Tubi midpipe, Dinan muffler, Dinan Monoballs, Dinan Stg 3 Suspension, Turner Sway Bars, Full powerflex bushings, Turner Adj. LCA w/ spherical bearings, full Bimmerworld suspension bearings, HPF reenforced subframe, function 7 guibo
Jump to top 802Hoop is offline   Reply With Quote
Old Sat, May-13-2017, 10:37:00 PM   #29
manueldtc
Reputation: 0 manueldtc is on a distinguished road
how much did the brackets and milling cost you , and do you have measurements of how much you have to shave off the calipers?
Jump to top manueldtc is offline   Reply With Quote
Old Mon, May-15-2017, 12:20:53 AM   #30
mrgicm
mrgicm's Avatar
Croatia
The brakes are mounted on the car I have done around 1000km with them, bedded them in and it is and immeadiete improvment, done some hard stops still with OEM M4 pads and just love how it brakes, the pedal feel has improved overall.
Love thats its all OEM+ which means I can get my discs in 2 days in any dealer for a known price. No mpre searching shipping waiting etc...
I can get the measurements for you if you wish.
On the front at forst it seems no modification whatsoever is needed but when trying to tighten it it is slightley off, so your choice is either scrub the hub or the calliper just a bit, which I did and also fitted some forge stainless steel brake lines for M4.
Discussing M4 Brakes on E46 M3? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
