Old Fri, Jan-05-2018, 12:12:07 PM   #101
r12tuning
Reputation: 0 r12tuning is on a distinguished road
Spain
Default Re: M4 Brakes on E46 M3?
Originally Posted by zaharias View Post
Do these fit in 18s?
Will it be ok if I put only the fronts?
I think that I have read that it fits in 18s but I can not I assure it.
At the moment I'm just going to put the forwards until I find someone to make me the rear support
Bilstein PSS10 Coilovers // HR Sway Bars // GSP Clutch Pedal// ASS Ultimate short shift// GruppeM Exhaust system // EvoSport Power Pulleys // RPi Ram Air Induction Scoop // OEM Rear Led Tail Lights // Leds AEs // OEM Bluetooth // 16:9 Complete Retrofit Kit // CSL Trunk
Jump to top r12tuning is offline   Reply With Quote
Old Fri, Jan-05-2018, 12:34:24 PM   #102
brungie
Reputation: 0 brungie is on a distinguished road
Default M4 Brakes on E46 M3?
So as the world is a small place, I now happen to own the car with gold calipers that was first posted in this thread. Canít say much that hasnít already been said but combined with fresh Pilot Sport 4S rubber Iíve put on, this setup provides immense stopping power and pedal feel is beautifly linear.
Got to be honest and say I have no idea which pads and fluid the car is running at the moment. Should ask mrgicm for previous ownerís contact so I can give a better insight into this an many other things done to my car.
2005 M3, TitanSilber, M Textur, 6MT, Slick top
KW V3, M4 Brakes, PS4S, OEM CSL Wheels, Boot and Diffuser
Jump to top brungie is offline   Reply With Quote
Old Sat, Jan-06-2018, 09:08:01 PM   #103
mrgicm
mrgicm's Avatar
Reputation: 0 mrgicm is on a distinguished road
Croatia
These are not OEM M4 discs used so the brackets and calliper modification is slightley different. I have the OEM M4 calliper and rotors and they fit under a 18" wheel (Team Dynamics Motorsport wheel) so cant say about other wheels.
Jump to top mrgicm is offline   Reply With Quote
Old Tue, Jan-09-2018, 07:35:51 PM   #104
Flanel
Flanel's Avatar
Reputation: 0 Flanel is on a distinguished road
Czech_Republic
Originally Posted by mrgicm View Post
I can get them for you if you are interested as I have mine now and no further measurments are needed, that is only if used with OEM M4 front and rear discs.
I have questions. M4 brake disc is different than M performance 34Oi brake disc? What exactly?
According to the catalog is different only diameter / average brake disc (380 vs 370)
Jump to top Flanel is offline   Reply With Quote
Old Tue, Jan-09-2018, 07:40:50 PM   #105
Flanel
Flanel's Avatar
Czech_Republic
I have a problem. The 34Oi M Perfomance brake disc is no good.
Ball joint is on the brake disc. I have a shim 2mm under the brake disc.
Please help me with your ideas.
Old Tue, Jan-09-2018, 10:46:09 PM   #106
r12tuning
Spain
My front calipers are in the machine and I can not check your problem it I have the front discs and If you want tomorrow I could do a Real measurements of it
Old Wed, Jan-10-2018, 04:59:01 AM   #107
Flanel
Flanel's Avatar
Czech_Republic
If you had a time, I'll be happy for any advice. At the moment i stopped on this problem. I do not know what to do.
Nobody had this problem with m4 rotors 380mm I have 370 mm performance rotors. But sizes rotors of m4 and performance are the same.
Brungie: have you pls photo ball joint and rotor ? You have the same rotors m performance 370mm
Thank you so much for your answers.
Old Wed, Jan-10-2018, 03:09:34 PM   #108
mrgicm
mrgicm's Avatar
Croatia
The M4 is a two piece and 340i is a one piece disc. you need an adapter to fit it properly in either case. You can see the 340 M performance discs on the silver car I posted in the thread above.
Old Wed, Jan-10-2018, 05:19:09 PM   #109
r12tuning
Spain
I have the m4 disc in the table and the D measure is not 73,1mm,in my disc is 62mm.
I think that is your problem,,the disc are not similar
Old Fri, Jan-12-2018, 03:31:34 PM   #110
Flanel
Flanel's Avatar
Czech_Republic
My parts dealer is an idiot. You're right. It has a bad catalog mark. M performance is 73,1. M4 is 62. This is my problem. I returned the rotors to the my dealer and I wait for M4 rotors.
Everything should be fine. I will keep informed. Thank you for your advice
Discussing M4 Brakes on E46 M3? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
