Old Mon, Jun-27-2016, 03:31:12 PM   #21
B_Engineering
B_Engineering's Avatar
Reputation: 0 B_Engineering is on a distinguished road
Germany
Default Re: SMG Pump Motor Replacement On Car - DIY
I'm sorry - brush motor;-)
Originally Posted by M3home View Post
Tks for reply. What means butst motor?
Jump to top B_Engineering is offline   Reply With Quote
Old Mon, Jun-27-2016, 03:33:45 PM   #22
M3home
Reputation: 0 M3home is on a distinguished road
Understand. Is there any testing comparing durability between stock and update motor/viscosity?
Jump to top M3home is offline   Reply With Quote
Old Mon, Jun-27-2016, 03:43:10 PM   #23
B_Engineering
Germany
For the new motor with new oil we perform different field tests (over years now).
Old Mon, Jun-27-2016, 03:44:18 PM   #24
M3home
Would be interested to know wear level compared with stock version.
Old Mon, Jun-27-2016, 03:45:36 PM   #25
M3home
Sorry for so many questions as I believe the change in viscosity is a good move. But as Engineer my background like to understand things in more details.
Old Mon, Jun-27-2016, 04:01:04 PM   #26
B_Engineering
Germany
This is absolutely no problem.
Unfortunately we do not have a direct compare with the old one. We are cooperation with a partner from the automotive industry which is also a major supplier of OEM.
During our tests we have recognized that the hydraulic pump was not able any more to build up the system pressure in the predefined time frame (the smg control unit gives a time frame which is important to protect the electric motor - component protecting). First sign is the cog light - here the control unit has activated the protecting - pump is not activated any more for a few seconds. When you have a lot hydraulic consumers (clutch activating or gear shifting e.g.) the pressure can fall below 50 bar - this is a limit were the smg control unit likes to see the car / gearbox in a safe state - neutral. After analyzing several hydraulic pumps we found out, that a very important parameter in this system is the efficiency of the pump. When the oil has high temperatures you loss a lot of pressure (also without hydraulic consumers) and efficiency due to the low viscosity.
Old Mon, Jun-27-2016, 06:53:49 PM   #27
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
Do you provide warranty for your motors?
Tischer aka GetBmwParts
Old Mon, Jun-27-2016, 07:32:21 PM   #28
B_Engineering
Germany
our motors come with a 12 month warranty.
Old Mon, Jun-27-2016, 07:49:18 PM   #29
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Forgive me if my question is redundant or just a bad question. I am pretty ignorant to the Ins-and-outs of these DC motors and am trying to understand them better. Is there any reason that these motors remain to be brush motors, rather than upgrading to a brushless design? Is there any reason or negatives to this motor being smaller than the OE motor (will it be working harder and thus wear out quicker?) Once again, sorry if these are poorly formulated questions. I am sure they suggest my lack of knowledge about what is being discussed. However, I appreciate you (BE) making these rebuild kits available to us. Your website has been favorited and will receive my business in the event my SMG ever gives me issues. Your products are a life saver to us SMG guys.
Old Mon, Jun-27-2016, 08:09:17 PM   #30
Marco Bleiker
Marco Bleiker's Avatar
Reputation: 0 Marco Bleiker is on a distinguished road
Switzerland
I've replaced two Motors on cars of friends of mine.
They had no problems with this replacement motors from burkhart engineering.
I'm very happy with this german guy
Great service and nice person.
Jump to top Marco Bleiker is offline   Reply With Quote
smg pump motor replacement, smg summertime blues
Discussing SMG Pump Motor Replacement On Car - DIY in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
