Old Fri, Dec-08-2017, 08:32:53 PM   #561
Originally Posted by Turb02 View Post
Maybe I dont know these tools enough (coding tools), but how would someone that is completely new to BMW coding, know what the new vehicle order is?
$793=SMG
????=6MT
Or am I looking at this the wrong way? Removing $793 doesnt have a replacement number, it has a new software flash instead, software 7837907 for non HP cars.
Sorry for the dumb question and if I missed it in this thread, I apologize.
There's no option code for the 6MT since it's standard equipment. You don't add anything after removing 793
Still have to reflash the DME
Old Sun, Dec-10-2017, 06:22:15 AM   #562
7rings
Reputation: 0 7rings is on a distinguished road
(any guidance on how to reflash the DME ?)
I have tried to flash the 6MT software to the DME using winkfp the car will not start it seems like there is an EWS error but when i check it with INPA there are no errors i have also tried to reset the ews with INPA but no luck .. when i load the original software to dme car starts fine but is stil low on power....
can anyone help me out with what else to look for
Thanks
Jump to top 7rings is offline   Reply With Quote
Old Tue, Jan-02-2018, 04:01:06 AM   #563
Al Soobie Guy
Reputation: 0 Al Soobie Guy is on a distinguished road
Thanks
Please elaborate " seems like an ews error, but no code" this is typically not a gut feeling type of issue. If it starts its not ews problem.
Must be something someone is missing, as then is there is no solution to removing the SMG from the module list tree... I know its not coding as i've used everythign form ISTAP to Win the other one.
Having the car run correctly and yet having the smg module part of the tree are mutually exclusive issues. Well not an issue, just an ocd component of incomplete...
Jump to top Al Soobie Guy is offline   Reply With Quote
Old Wed, Jan-03-2018, 07:16:47 PM   #564
7rings
[QUOTE=Al Soobie Guy;1067766788]Please elaborate " seems like an ews error, but no code" this is typically not a gut feeling type of issue. If it starts its not ews problem.
After i loaded the 6mt software the car would crank but not start when i loaded the original software back the car started fine
what is the 6mt software # ppl are using ?
Thanks
