Old Tue, Sep-25-2018, 08:31:37 PM   #1
mdkcrf250r
Reputation: 0 mdkcrf250r is on a distinguished road
Default F8X Lithium battery
Hey guys, it's been a long time but I'm back in an e46 M3 again. The car I just purchased needs a new battery so I'll be going with an F8X lithium ion battery as it's lightweight and free for me. I did some research but nothing definitive regarding whether it will work or not and whether anyone has tried it yet. I'm 98% sure it will be fine but I'll report back with the results after installation and 1 month later.
Jump to top mdkcrf250r is online now   Reply With Quote
Old Tue, Sep-25-2018, 08:50:06 PM   #2
Default Re: F8X Lithium battery
What are the CAs and reserve ratings? Weight? This thread needs a little something more imo
_
Old Tue, Sep-25-2018, 09:21:09 PM   #3
HassanEido
HassanEido's Avatar
Lebanon
Does this battery have battery protection built in? Yes: go for it, no :get battery protection.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Wed, Sep-26-2018, 01:50:04 AM   #4
http://www.m3forum.net/m3forum/showthread.php?t=482085
Old Wed, Sep-26-2018, 09:15:20 AM   #5
mdkcrf250r
Well I'm forced to abandone this project as the battery that was free to me is no good so I'll just be purchasing a lightweight racing battery. The F8X lithium battery relies on a battery management module the F8X cars are equipped with. The battery itself has an internal safety switch for situations of extreme heat, overcharging or under charging and without the signal from the battery management module to control the safety switch there is no protection. Basically it just isn't worth finding out and especially true if you have to purchase the lithium battery.
Old Wed, Sep-26-2018, 12:28:51 PM   #6
HassanEido
HassanEido's Avatar
Lebanon
I'm glad you decided to dig into this, as Lithium ion batteries can start fires if not managed for safe charging and discharging. You could put together a safety module, but personally I would take the route u eventually went with.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Discussing F8X Lithium battery in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
