Old Mon, Feb-14-2011, 05:12:42 PM   #1
dannylu88
Reputation: 0 dannylu88 is on a distinguished road
Default Control Arms replacement cost?
Hello all,
I recently brought my 03 M3 in for a long overdue coil springs replacement. The reputable indy shop I took it too replaced the oe ones with the eibach pro kit.
When they suggested doing an alignment I went with it and they said that they couldn't do it because the control arms are going and I need them replaced, bushings as well.
My question to the board is that how much should it cost to replace the control arms, and how long can I keep on driving before it needs to get done? Any recommended brands?
Thanks
Jump to top dannylu88 is offline   Reply With Quote
Old Mon, Feb-14-2011, 05:24:07 PM   #2
mpegripper
mpegripper's Avatar
United Kingdom
Default Re: Control Arms replacement cost?
which control arms? front, rear upper or rear lower?
Old Mon, Feb-14-2011, 05:24:52 PM   #3
ianmason
ianmason's Avatar
Reputation: 0 ianmason is on a distinguished road
they are alot. I'm having the left rear replaced as we speak. OE is the only way I would go with these. Not even sure if they are aftermarket available.
Would the control arms "go"? They are hunks of metal, unless they are bent I dont' see how they deteriorate. And why not the trailing arms?
Jump to top ianmason is offline   Reply With Quote
Old Mon, Feb-14-2011, 06:17:45 PM   #4
mpegripper
mpegripper's Avatar
United Kingdom
if its the front control arms, it could be the ball joints going bad. the only way to replace those is by replacing the whole arm.
Old Mon, Feb-14-2011, 06:22:39 PM   #5
dannylu88
Yeah they said the ball joints were going bad and that's why they couldn't do the alignment. And they also recommended replacing the bushings as well.
Any guesses on cost and how long I can drive on this thing before taking it in?
Thanks again guys
Old Mon, Feb-14-2011, 06:23:58 PM   #6
mpegripper
mpegripper's Avatar
United Kingdom
based on what they said, the control arms about $600 online and fcabs are definitely cheap ($25) and worth doing at the same time (only a few extra minutes of labor)
i'd do it asap as you will get crazy wear on your tires
expect to pay about $200 in labor
Old Mon, Feb-14-2011, 06:26:10 PM   #7
mpegripper
mpegripper's Avatar
United Kingdom
control arms:
http://www.trademotion.com/partlocat...catalogid=4462
bushings are part number 31122229857, need 2
Old Mon, Feb-14-2011, 07:35:30 PM   #8
dannylu88
Thanks for that info mpeg, I'm planning on doing it as soon as possible just wondering if crazy wear on the tires the only thing I would need to worry about until then or is my irrational fear of part of the suspension breaking down on the highway justified?
Old Mon, Feb-14-2011, 08:19:07 PM   #9
mpegripper
mpegripper's Avatar
United Kingdom
i personally drove on it with bad ball joints for 4 months
Old Wed, Feb-16-2011, 11:35:24 PM   #10
coolatif
Imola My Life..
coolatif's Avatar
Reputation: 0 coolatif is on a distinguished road
Originally Posted by mpegripper View Post
control arms:
Thanks for the link.. I just placed an order. It's a great price for OEM Control Arms..
Jump to top coolatif is offline   Reply With Quote
control arm, cost, e46, installation, replacement
Discussing Control Arms replacement cost? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
