Old Sat, Oct-31-2009, 03:55:34 PM   #1
e46m3guy
Reputation: 0 e46m3guy is on a distinguished road
Default Was Urgent RTAB help please, now Comedy of Errors
I've disconnected the RTAB console but the arms haven't dropped below the side skirts so i don't have enough space to remove the bolt that holds the console to the RTAB
What can I do to make the arms droop lower? I have both sides unhooked but that didn't seem to help.
Thanks.
EDIT: Note that the car has tein springs on it.
Jump to top e46m3guy is offline   Reply With Quote
Old Sat, Oct-31-2009, 04:02:18 PM   #2
Disconnect bottom of shock, car in neutral, ebrake off
Old Sat, Oct-31-2009, 04:04:11 PM   #3
e46m3guy
is it ok to move it into neutral and take it out of gear with it on the jack stands?
To unbolt the bottom of the shock should I just support the arm with the jack and unbolt the one bolt? Thanks!
Old Sat, Oct-31-2009, 05:26:49 PM   #4
EricSMG
40 something
Yes and yes. Then use a short length of 2x4 to wedge the front of the arm down from the chassis for easy access to the console/bushing.
It's a pain but doable.
2004 E46 M3 6MT SG/Black
Old Sat, Oct-31-2009, 06:06:19 PM   #5
e46m3guy
well I seem to have gotten it low enough, but the existing bushings have the flange on them so the autozone rental bearing puller (C clamp) method won't really work.
I'm waiting on an e46fanatics member who has offered to let me borrow his rtab tool so I can continue.
Old Sat, Oct-31-2009, 07:22:06 PM   #6
Reach
Reach's Avatar
Reputation: 0 Reach is on a distinguished road
Let this be a lesson to you and others: do not start this job without the rtab tool by your side!
Jump to top Reach is offline   Reply With Quote
Old Sat, Oct-31-2009, 07:26:38 PM   #7
e46m3guy
I had really high hopes for the autozone rental method, but oh well.
Old Sun, Nov-01-2009, 12:15:34 AM   #8
evannever
Reputation: 0 evannever is on a distinguished road
You CAN do it with the flanges on the RTABs and the Autozone tool. You just take a screw driver and hammer and bend the flanges in so the bushing cup seats against the trailing arm. You can use a set of vise grips to tear off the flanges once you have bent them in with a screw driver. You wont dammage the trailing arm and you'll see how easy the flanges are to bend.
I explained it in more detail in this thread.
I also added my $.02 to this thread on E46 fanatics.
Also, I found a good way for dropping the trailing arm enough to work on it was:
1) make sure the parking break is off
2) I used my floor jack to lift in the bottom of the shock mount and compress the shock. This rotated the trailing arm without having to unbolt anything.
Jump to top evannever is offline   Reply With Quote
Old Sun, Nov-01-2009, 01:24:56 AM   #9
alanbmoore
alanbmoore's Avatar
Reputation: 0 alanbmoore is on a distinguished road
Be careful with the driveshaft, with the shock disconnected I believe it's possible to overextend the joints on the driveshaft and possibly damage it.
Why bother with the RTAB tool if you have 10 chisels, 3 extra thumbs, and a replacement rocker panel?! I can't understand why anyone would try this without the correct tool. Buy it, use it, sell it for $20 less than you paid. Done!
-Alan
'04 M3 - SMG
'94 E36 track car
'87 Mazda RX7
Hotchkis sways - 2.5deg front camber - 18x9.5 VMR CSL reps - Nitto NT-01 275s - PFC06's - Schroth Quickfit
Jump to top alanbmoore is offline   Reply With Quote
Old Sun, Nov-01-2009, 01:27:40 AM   #10
e46m3guy
I got the proper tool from someone local on e46fanatics so I'll give that a shot tomorrow. Good idea about jacking up the shock to rotate things. I'm going to bolt it back up and try that since unbolting didn't really drop it much at all.
rtab, urgent
Discussing Urgent RTAB help please in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
