Old Thu, May-16-2019, 08:24:33 PM   #1
ttruongm5
Reputation: 0 ttruongm5 is on a distinguished road
Default Car struggles to start on cold start
The car will start up every time, but it really struggles and kind of hesitates to get up to the normal RPM once the ignition starts.
Spark plugs are new, vanos was recently overhauled except for the solenoid. I'm wondering if this is the fuel pump going out? Maybe Coil packs? Car also feels very sluggish/not as much "get up and go" as usual. Any help is appreciated. Mileage is 123k
Jump to top ttruongm5 is offline   Reply With Quote
Old Fri, May-17-2019, 02:14:09 AM   #2
ttruongm5
Default Re: Car struggles to start on cold start
Valves also recently adjusted so those can be ruled out
Old Fri, May-17-2019, 02:18:12 AM   #3
Race M3
I can put whatever I want here?
Reputation: 0 Race M3 is on a distinguished road
Any fault codes?
Jump to top Race M3 is offline   Reply With Quote
Old Fri, May-17-2019, 02:29:06 AM   #4
ttruongm5
Just ordered this scanner to find out, will report back after I get a chance to read the codes. I currently have headers installed without rear O2s so not sure if any codes will overlap with that, but we will see
Discussing Car struggles to start on cold start in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
