Old Thu, May-16-2019, 06:44:59 PM   #1
Whitehawk8
Whitehawk8's Avatar
Reputation: 0 Whitehawk8 is on a distinguished road
Default Snapped the UPDATED diff bolt
Essentially I was finishing up a track day. On the last session I floor it and hear the typical noise in the back.
Im taking a look in the paddock when I see half the bolt stuck in the subframe. Anyways I got home 130 miles away by ratchet strapping the diff to the subframe. Ill include a picture for your amusement. Id recommend doing this instead of paying for a tow, only took 30 minutes and saved me over $600 for a tow. Just be sure to drive VERY easy on the way home or to your shop or the straps may break from the torque.
Anyways here's my theory. I kept hearing a sliiiiight tapping noise first thing in the morning when pulling away in 1st gear. My e-brake is sorta noisy so I just dismissed it as that. This noise existed for 2 weeks maximum. Is it possible the old bolt backed out?
The shop I took it to says the bolt didn't in fact back out but simply snapped because of my bushing setup. I have rubber bushings everywhere except for my subframe bushings which are solid. My RTABs are the CMP ones with a rubber sleeve inside.
So, who can help diagnose my problem?!
2003 M3 StahlGrau Metallic | Beisan | JB Racing | Koni | CMP | TMS | OEM SSK
Jump to top Whitehawk8 is offline   Reply With Quote
Old Thu, May-16-2019, 07:08:18 PM   #2
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Default Re: Snapped the UPDATED diff bolt
Was the proper installation sequence followed?
Insert front bolt
Insert rear bolts
Tighten front bolt (200 NM)
Tighten rear bolts (20nm, 90 degrees)
E46 ///M325i Touring journal
Old Fri, May-17-2019, 03:48:51 AM   #3
Whitehawk8
Whitehawk8's Avatar
Insert front bolt
Insert rear bolts
That Iím not sure of. I will need to ask the shop
Old Sun, May-19-2019, 12:17:17 AM   #4
Aleksey
Reputation: 0 Aleksey is on a distinguished road
In the same boat here! Didn’t race, was pulling away from light and passenger side bolt head snapped.
Any idea how your shop will get it out?
Btw, bolts were “new” design. And original bushings.
BMWCCA# 468264
Join & use my BMWCCA member number @ www.bmwcca.org to get rewards and a chance to win! www.bmwcca.org/membershipdrive
Jump to top Aleksey is offline   Reply With Quote
Old Sun, May-19-2019, 02:33:35 AM   #5
I would use a stiffer bushing at least for the bolt most prone to snapping. Use 10.9 or 12.9.
Discussing Snapped the UPDATED diff bolt in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
