Old Thu, May-16-2019, 04:33:04 PM   #1
LightlyToasted
Reputation: 0 LightlyToasted is on a distinguished road
Default what rod bolts am I likely to have?
MY2001, manufactured 04/2001. Block was replaced Nov 2003 at 58k km under warranty due to rod bearing failure which punctured the block.
I'm at 211k km now, and my latest Blackstone report shows elevated lead and copper, so I guess it's my turn for rod bearings.
What rod bolts am I likely to have (orig M11 or newer M10), given that the block was replaced in 2003? I'll find out soon enough when I'm in there, but I'd like to know if I should buy the new bolts prior to taking everything apart.
Jump to top LightlyToasted is offline   Reply With Quote
Old Thu, May-16-2019, 04:34:18 PM   #2
mdavidm3
Reputation: 0 mdavidm3 is on a distinguished road
Default Re: what rod bolts am I likely to have?
If replaced in 03 most likely have newer style bolts. You can always buy both and return the ones you done use
Trackspec Autosports
MMI Vehicle Systems
Ravenol
G-LOC Brakes
IG: marcdavid.m3
Jump to top mdavidm3 is offline   Reply With Quote
Old Thu, May-16-2019, 05:36:47 PM   #3
bimmerfan08
bimmerfan08's Avatar
Probably M10 bolts. Worst case scenario: buy them and if you don't need them, just return them.
"The most difficult part of figuring out a car, the engineering, has been accomplished. Repairs and maintenance are simply dissembling parts and reassembling them." - bimmerfan08
Old Thu, May-16-2019, 05:37:33 PM   #4
bimmerfan08
New M11 bolts aren't available these days. BMW advises to reuse the M11 bolts in the engine.
Old Thu, May-16-2019, 07:20:42 PM   #5
Mr.wReckless
Mr.wReckless's Avatar
Reputation: 0 Mr.wReckless is on a distinguished road
Norway
Apparently I've heard (although I appreciate it's hearsay) the rods and old M11 bolts were a bit inferior to the new M10's.
That being said, I concur and you'll likely have the new M10 bolts in your engine. No worries to get them both and then just return the set you won't need. I've got a set of M11 bolts from ARP on order in preparation of doing my rod bearings, and I'm actually a bit curious what type of bolt I'll find once I dig into the belly of the beast as I have no record of a recall or such.
Regards
Jump to top Mr.wReckless is offline   Reply With Quote
Old Thu, May-16-2019, 08:37:18 PM   #6
LightlyToasted
Thanks for the info - I'll buy M10 bolts. I've assumed that the "hole in the block" listed on the original owner's work order was caused by a rod bearing failure which must have at least destroyed the rod, meaning new rod + new bolts with the new block.
Spun rod bearings typically destroy both the rod and crankshaft, no?
Old Fri, May-17-2019, 08:37:05 AM   #7
Mr.wReckless
Norway
Yes. I've not heard of a spun bearing that hasn't scored the crank journals.
Regards
Old Sat, May-18-2019, 11:52:51 AM   #8
dutchhome
Reputation: 0 dutchhome is on a distinguished road
A quick word of caution if you end up going with M11 ARP bolts. Do not follow their alternate torque option and instead measure the stretch of the bolts directly. I used a torque wrench and a stretch gauge and noticed the torque needed to achieve the correct stretch was quite a bit off from their alternate torque value and each one was different.
Jump to top dutchhome is offline   Reply With Quote
Old Sat, May-18-2019, 01:40:48 PM   #9
Mr.wReckless
Norway
I did a bit of searching around this, as I too have heard about the out of round issue with torquing the ARP bolts. Though I have found a thread where a guy from Lang Racing and fellow forum user tested this and it seemed from his finding the M11 size actually wasn't too bad, however the M10 ARP was a bit further off when using torque rather than stretch. From memory the ARP recommended torque for the M11 is 70 ft/lbs and he got them bang in the middle of spec with 68 so in my book that's close enough to ARP's recommendations. The M10 was a different story though.
post #72
http://www.m3forum.net/m3forum/showt...lts+oem&page=8
Regards
Old Sat, May-18-2019, 01:53:16 PM   #10
dutchhome
Post #76 shows that even Lang recommends the stretch method. In my case I found wildly different torque values required to achieve the amount of stretch required. The first several bolts had me second guessing my method so I removed, remeasured, and retorqued. It may be that Lang simply stopped after testing one bolt that showed the torque matched what ARP suggested.
If I were to do it over again I would use plastigauge on every bearing and triple check everything.
Discussing what rod bolts am I likely to have? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
