Old Thu, May-16-2019, 03:33:37 PM   #1
E46 Mystic M3
Reputation: 0 E46 Mystic M3 is on a distinguished road
Default SMG INPA Adaptation Passes with No Errors, Cannot engage 1-3-5 gears
Just replaced the gear position sensor and I used INPA to adapt the SMG. No errors whatsoever, and I did it in order from f1-f3. Once finished, I cannot engage gears 1-3-5 and the smg light comes on. I know its not the gear position sensor because i put in a different smg computer and it shifts in all gears, just a little sloppy. What am I doing wrong? I want to use DIS to adapt the clutch but my DIS software isn't recognizing the car. Any help appreciated, this has been driving me crazy.
2002 M3 Convertible SMG Steel Gray/Imola Red
1997 Toyota 4Runner SR5 (Daily)
2004 M3 Coupe SMG Mystic Blue SOLD
1997 M3/4/5 Dakar Yellow AA Stage 1 Supercharger SOLD
2004 M3 Coupe 6MT Laguna Seca Blue SOLD and very missed
2002 745i Sterling Grey SOLD, gone and not missed
Instagram: @thetypicalm3guy
Jump to top E46 Mystic M3 is offline   Reply With Quote
Old Thu, May-16-2019, 10:26:21 PM   #2
aznniche
aznniche's Avatar
Default Re: SMG INPA Adaptation Passes with No Errors, Cannot engage 1-3-5 gears
Usually skipping gears are compression springs related. You didn’t change them?
Jump to top aznniche is online now   Reply With Quote
Old Fri, May-17-2019, 07:32:54 AM   #3
E46 Mystic M3
I just replaced the compression springs. They were also not broken when i replaced them.
Old Fri, May-17-2019, 05:40:05 PM   #4
sapote
give us the some background of car before the works were done.
Old Sat, May-18-2019, 07:00:54 AM   #5
SMG cog light
If you cannot engage gears 1,3,5 check the hydraulic line on the far left on the smg pump/hydraulic control unit. (on left when standing in front of car facing the hood)
That is the Hydraulic Line for Shift Travel 1
Gears 1,3,5. Follow this line to the gearbox actuator and check that the lines are tight and not leaking.
Hydraulic Line for Shift Travel 2
Gears 2,4,6 is on the opposite end of the HCU on the far right.
There are 2 shift travel solenoids on the HCU. (1 for gears 1,3,5, and one for gears 2,4,6) The solenoids work in conjunction with the pressure control valve mounted inside the gearbox actuator. The other 2 solenoids are; one for clutch control and 1 for selection angle cylinder actuation.
The piston in the shift travel cylinder must be moved in both directions (in/out) by pressure. Two pressure control valves are required to achieve this movement. With no current applied to the valves they are in the open position allowing connection of the cylinder chamber and the expansion tank. Applying current to one of the solenoids will cause hydraulic fluid to flow against the cylinder piston pushing it in one direction. Fluid from the other side of the piston will be forced through the second control valve into the expansion tank.
The position sensor that you installed is mounted directly onto the selection angle cylinder. check to see that it is installed properly. (car should also be in neutral during installation)
Jump to top SMG cog light is offline   Reply With Quote
Old Sat, May-18-2019, 05:31:26 PM   #6
E46 Mystic M3
I think I was a little unclear about the problem. I have narrowed the problem down to a SOFTWARE issue since I have one smg computer that works fine but sloppy and one smg computer that cannot engage 1-3-5 after inpa adaptations. inpa adaptations ran with no error and then I couldn’t engage those gears. What am i doing wrong? Does anyone have DIS in the socal area that could help me out? Ive heard better things about DIS adaptations.
Old Mon, May-20-2019, 09:45:55 PM   #7
E46 Mystic M3
Anyone?
Old Mon, May-20-2019, 10:37:42 PM   #8
jared212
Reputation: 0 jared212 is on a distinguished road
Did you put the GPS in upside down?
'04 SGM/Blk|SMG|AA/FS Prima Elite kit|Hacksaw built engine w/ JE/Molnar/Supertech/ARP/lots of ceramic TBC|ID1050x injectors|Radium rail+FPD-XR|Aeromotive FPR|-6an fuel system walbro 450 e85|RMS headers|Magnaflow custom 2.5" sec1|Besian|Redish|ZCP springs/Koni's|Hotchkis front sway bar+deleted rear|Turner Pulleys|Southbend stg 3 DD clutch|Innovate/Spek gauges|relocated SMG|Mishi OCC|Koyo Radiator|CSF oil cooler|basically stock interior and exterior
Jump to top jared212 is offline   Reply With Quote
Discussing SMG INPA Adaptation Passes with No Errors, Cannot engage 1-3-5 gears in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
