Old Thu, May-16-2019, 03:22:31 PM   #1
BrianC
Reputation: 0 BrianC is on a distinguished road
Default Tighten Up Shifter?
Is there any way to tighten up the shifter linkage on a 2002 E46 6MT M3?
We just used metal washers in place of the bushings on the old Taurus SHOs to do it, but that's American car. I'm not sure how to do it on a German car yet.
Jump to top BrianC is offline   Reply With Quote
Old Thu, May-16-2019, 03:25:50 PM   #2
Default Re: Tighten Up Shifter?
Best one for me is the delrin shifter carrier bushings in place of the soft rubber. I don't subscribe to replacing the rear bush with poly, as some will likely suggest.
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
Old Thu, May-16-2019, 07:31:47 PM   #3
BrianC
Thanks, Tbone. Mind if I ask why you don't recommend the rear bushing?
Old Thu, May-16-2019, 07:38:44 PM   #4
lmtfi
lmtfi's Avatar
Try a new Delrin shifter cup.
Old Thu, May-16-2019, 07:43:01 PM   #5
rbg
Reputation: 0 rbg is on a distinguished road
Thatís interesting. Never seen derlin cup, only bushings. Mind posting a link? Thanks!
Jump to top rbg is offline   Reply With Quote
Old Thu, May-16-2019, 07:46:42 PM   #6
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Get an Autosolutions shift kit :-)
E46 ///M325i Touring journal
Old Thu, May-16-2019, 07:50:24 PM   #7
It seems like, since it's not solid rubber, it only holds the back of the carrier, locates it. Then, introducing really stiff compound like poly just transmits more tranny NVH to your hand.
I think it was one of those, "what other products can we sell that are made out of poly?"
_
Old Thu, May-16-2019, 08:01:30 PM   #8
BTB
BTB's Avatar
I've got the delrin carrier bushings and fresh stock bits everywhere else, with the shorter oe e60 shift lever. Very tight, only starting to get slightly worn ~30k miles later. Good budget option, otherwise get an autosolutions kit if you can afford it.
My Journal
Jump to top BTB is online now   Reply With Quote
Old Fri, May-17-2019, 03:27:36 AM   #9
BrianC
Thanks for the info. I'll probably use the delrin carrier bushing and shifter cup (I'm having trouble finding it, though). I'm gonna hold off on it for now, but I'll get around to it, eventually.
Old Fri, May-17-2019, 04:13:40 AM   #10
///ALpineVert
Reputation: 0 ///ALpineVert is on a distinguished road
This.
Jump to top ///ALpineVert is offline   Reply With Quote
Discussing Tighten Up Shifter? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
