Old Thu, May-16-2019, 02:14:48 AM   #1
jpiazzam3
Reputation: 0 jpiazzam3 is on a distinguished road
Default Rear shock mount reinforcement
Iím going to be installing konis and eibachs. But I have Dinan strut braces both front and rear. I couldíve sworn Iíve read somewhere that the rear dinan bar mounts will double as reinforcement plates. Is this true ????
Jump to top jpiazzam3 is offline   Reply With Quote
Old Thu, May-16-2019, 02:27:36 AM   #2
Zzyzx85
Zzyzx85's Avatar
Reputation: 0 Zzyzx85 is on a distinguished road
Default Re: Rear shock mount reinforcement
If it's the same as this one (http://www.m3forum.net/m3forum/attac...1&d=1557846137) it'll work as a reinforcement plate.
Jump to top Zzyzx85 is online now   Reply With Quote
Old Thu, May-16-2019, 02:33:09 AM   #3
STAATS
STAATS's Avatar
Yer I would have thought basically every rear strut brace for the E46 would double as a Rear Shock Tower Reinforcement also... due to the way they have to tie/bolt int to the top of the strut.
That't the only reason I bothered with a Mason Engineering Rear Strut brace... I figured I may as well get a little something extra out of it vs just installing reinforcement plates haha
STAATS
Old Thu, May-16-2019, 04:08:37 AM   #4
Paulo M
Thatís a huge price jump tho lol
BREMBO APEX DIXIS
Old Thu, May-16-2019, 12:00:52 PM   #5
a) yes, they will
b) it doesn't really matter-- our rear towers aren't prone to failure like the e36 was (which is why people reinforce this area), and the front is plenty strong as well as you don't run a camber plate that spreads the load poorly.
Old Thu, May-16-2019, 02:01:30 PM   #6
jpiazzam3
Thanks fellas. Any recommendations on front and rear shock/strut mounts
Old Thu, May-16-2019, 02:30:11 PM   #7
There's not really any reason to move off stock unless you're looking for more precision (monoball, at the expense of NHV) or adjustment (camber plate). If you are looking for one of those, depends how your using the car/what you want from it.
Old Thu, May-16-2019, 05:08:30 PM   #8
jpiazzam3
Oem it is. Thank you
Discussing Rear shock mount reinforcement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
