Old Wed, May-15-2019, 09:09:32 PM   #1
Exclusivs
Exclusivs's Avatar
Reputation: 0 Exclusivs is on a distinguished road
Question Clutch & Dual Mass Flywheel : SACH's, LUK or Genuine?
Whats up guys,
Looking to get advise on parts prior to diving into planned:
New: Clutch
Flywheel
From great previous threads : LUK seems the go -to & OE maker of the Clutch / and DMFlywheel. The "clutch kits" by LUK may possibly need a genuine part throw in to compensate from what I am getting.
SACHs always a quality brand - anyone prefer to use this clutch kit over LUK?
As far as DMF, I gather its debated on replace vs not. I'm going to do so, because "While in there." But also don't want to drop trans again to replace down line (10-20k). Is LUK regarded as the go-to DMF for you guys who have replaced?
Mainly looking for guys who have been running these parts now for the long haul trouble free. Or if any issues, pls advise as any help would be greatly appreciated!
Figure, id start this as a new topic because I haven't seen any recent threads on this and not sure if anything has changed.
Cheers!
Jump to top Exclusivs is offline   Reply With Quote
Old Wed, May-15-2019, 09:20:19 PM   #2
M3_Pilot
Default Re: Clutch & Dual Mass Flywheel : SACH's, LUK or Genuine?
I installed the LUK clutch and flywheel. Works as advertised.
The only difference I can tell from the OE and the LUK unit is that LUK has a bit more chatter in the lower rpm's. That's it.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Old Wed, May-15-2019, 10:00:27 PM   #3
Zzyzx85
Zzyzx85's Avatar
Reputation: 0 Zzyzx85 is on a distinguished road
LUK clutch, pressure plate and DM flywheel, OE pilot bearing, and Sachs throwout/release bearing
20k miles on it and happy with the setup.
Jump to top Zzyzx85 is offline   Reply With Quote
Old Thu, May-16-2019, 12:16:50 AM   #4
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Clutch disk and pressure plate are the same between both kits.
Throwout bearing: The Sachs is what the car comes with from BMW. The LuK is different but still a perfectly good and reliable part.
Pilot bearing: The Sachs kit does not include one. The LuK kit includes a garbage one. Use a genuine BMW (NTN, Japan) bearing.
Old Thu, May-16-2019, 01:36:55 PM   #5
GeorgeH
BMW Fan
Reputation: 0 GeorgeH is on a distinguished road
+1 Everything above, but absolutely this!
Current BMW stable: '00 R1100S, '09 HP2S, '12 R1200GSA, '00 323iT (S54 Swapped), '00 332iT (stock), '03 325iT (stock), '04 ZHP Imola/6MT (basic suspension mods)
Jump to top GeorgeH is online now   Reply With Quote
Old Thu, May-16-2019, 05:35:13 PM   #6
ATB88
Reputation: 0 ATB88 is on a distinguished road
Originally Posted by GeorgeH View Post
[/B]
Back when I did my swap I had done enough research to know that the LuK throwout bearing was not OE, but I didn't know about the pilot bearing and used the one supplied with the kit (I think it's Korean made).
10k on it now, no issues. While one can worry that this pilot bearing may be overall less reliable and may not last as long as the OE pilot bearing, are there any known horror stories about these failing? What happens when a pilot bearing fails, anyway?
Jump to top ATB88 is offline   Reply With Quote
Old Thu, May-16-2019, 06:11:03 PM   #7
GeorgeH
BMW Fan
I tried a couple before I immediately started throwing them away. I found the outer diameter is too small and the pilot bearing will not seat into the crankshaft. I was concerned that it could "move" and either wear the bearing surface or jam itself into the input shaft or crankshaft causing failure.
Old Thu, May-16-2019, 09:08:12 PM   #8
Exclusivs
Exclusivs's Avatar
Thanks for chiming in guys! Especially those who have put decent miles on the new parts. Please continue to post for those who have done refresh.
Did you use the LUK pilot that was included in the kit?
This is awesome! 20k is healthy mileage and looks to be the go/to combo. Hard to say no to SACHS.
Thanks Kev! Exactly what I intended to confirm These are the valuable small details of amazing work put together by great members on this board! Especially all your hard work and continued contribution of info!
Old Thu, May-16-2019, 09:18:45 PM   #9
For what it’s worth, the Sachs clutch kit I bought still came with a LuK throwout bearing, much to my annoyance. Seems the only reliable way to get the Sachs bearing is to just buy it separate through bmw.
Old Thu, May-16-2019, 09:24:49 PM   #10
M3_Pilot
Yes, LUK everything.
@jet.m3
Discussing Clutch & Dual Mass Flywheel : SACH's, LUK or Genuine? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
