Old Wed, May-15-2019, 06:28:24 PM   #11
tr4ck_m3
Buildjournal
tr4ck_m3's Avatar
Reputation: 0 tr4ck_m3 is on a distinguished road
Default Re: Headers and ECU Tune now I have white smoke
Hey toof,
It really does seems like a hardware issue somewhere. I doubt that the tune could cause this, especially on first start up with the new tune since most of those parameters are kept stock. If the fueling was off, your car would not idle smooth either. And like the others have said, the post o2 are emissions only - your pre o2 will refine your AFR corrections.
You can also rule the tune out, by flashing the stock tune back on and see if it still happens.
It is possible that after that track day last month- your gasket components cooled/shrunk down developed a crack in some seal somewhere.
Maybe check your coolant levels or engine cap for moisture?
Expansion tank leaking?
White sounds like coolant or water making its way into your engine. Black usually means oil+fuel.
As for the header gaskets did you use OE gaskets?
How is the water temperatures - rising temperatures in idle may mean head gasket.
Or if you had new headers installed, it is likely coated with oil of some sort.
IG: @tr4ckM3
B-Spec Tune
2002 BMW E46 M3 6MT | B-Spec Tune + ProFlex Commander E70 315whp/242wtq
2013 BMW F30 335i 8AT | BM3 E30 Stg 2 Tune 367whp/457wtq
Jump to top tr4ck_m3 is offline   Reply With Quote
Old Wed, May-15-2019, 07:55:56 PM   #12
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Originally Posted by stash1 View Post
Out the tail pipe Hassan, or just under the hood? I think that OP just mentioned (in post #5) that it's only smoking from the tail pipe. OP, does it smoke all of the time, or just at start up/idle? I just can't see how a tune would make a car smoke unless you blew a head gasket or something already? Have you driven it hard yet since the header/tune install, or has it just been sitting there idling in your garage so far?
Yea I'm right in line with what you are thinking here. If anything, I'd expect for it to smoke under the hood while the oils are burned off the new headers. Mine did briefly...also freaked me out.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2
Old Wed, May-15-2019, 10:55:18 PM   #13
toof
Reputation: 0 toof is on a distinguished road
So run the car around the neighborhood just to keep everything greasy at least once a week and never any smoking.
I used the header install kit from Bimmerworld. The gaskets looked better quality than the ones removed.
I dropped it off at the shop at the track this evening and drove it around the skid pad. No smoke that I could see but the wind was up to a consistency 3-5 MPH.
Temps are good on water and oil but have not pushed the car hard yet.
Jump to top toof is offline   Reply With Quote
Old Thu, May-16-2019, 12:53:28 AM   #14
toof
Another thought Iím having is that I may have plunged the O2 sensors into the wrong connector.
Do the Pre (or forward) sensors go under the plastic wire loom cover? Or at the rear of the head side by side?
Old Thu, May-16-2019, 01:34:17 AM   #15
ThunderMoose
Rear of head side by side
#67 2017 NASA TX TT3 Champion
Old Thu, May-16-2019, 03:18:45 PM   #16
toof
Thats where they are now. Well I'll be running "flat out" lol this afternoon.
We will see what happens. I need to do a proper shake down for NASA Summer Shootout at Hallet in 3 weeks.
Discussing Headers and ECU Tune now I have white smoke in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
