Old Wed, May-15-2019, 02:20:47 PM   #1
toof
Reputation: 0 toof is on a distinguished road
Default Headers and ECU Tune now I have white smoke
I installed headers and the tune from The Build Journal last weekend and now the car is smoking. Its now billowing smoke but it is noticeable. I have ran the car at idle for about 45 min and the smoke increases with RPM.
Could this be adjustment of air/fuel mix now that the rear O2 sensors are gone?
This is a dedicated track car and 2 months ago at the last weekend I had zero smoke and zero issues.
I did replace the CPV seal and used new exhaust gaskets.
Jump to top toof is offline   Reply With Quote
Old Wed, May-15-2019, 02:29:40 PM   #2
Drewster
Drewster's Avatar
Default Re: Headers and ECU Tune now I have white smoke
What color is the smoke and where is it coming from? The headers will smoke since they're usually covered in oil from manufacturing.. but if you've got lots of white smoke coming out of your tailpipe you probably need to investigate a little further.
Old Wed, May-15-2019, 02:36:07 PM   #3
Ya from engine area or from tailpipe?
Probably just grease and coolant burning off from header job.
Post cat O2s dont affect AFR afaik, only emissions purposes.
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
Old Wed, May-15-2019, 02:57:13 PM   #4
stash1
Op said that he ran the car for at least 45min...that should've burned off any residual grease/spilled coolant from the header job. Double check for any exhaust leaks and or/coolant leaks still dumping coolant on the headers. Also recheck your CPV job to make sure oil isn't leaking. Doubtful the smoke is a result of the tune. As the others said, where exactly is the smoke coming from?
'04 AW/IR...some mods
Old Wed, May-15-2019, 02:58:26 PM   #5
toof
Tail pipe
The smoke looks very faint but appears white but I might be able to convince myself its a shade of blue.
I also sprayed some brake cleaner on the head to clean the header mounting surfaces. I would assume that would burn off quickly (less than a couple min).
I cannot see the smoke in my rear view mirror, it dissipates a couple feet from the tail pipe.
Old Wed, May-15-2019, 03:00:02 PM   #6
toof
I'll double check torque on the header bolts this afternoon but I was pretty good about getting them torqued.
Old Wed, May-15-2019, 04:01:05 PM   #7
SamGrant951
SamGrant951's Avatar
Reputation: 0 SamGrant951 is on a distinguished road
When I installed new headers/sec1 it did the same thing, I was freaking out - did a compression test/etc. After about 30-45min of letting it idle/smoke I just went and drove it a few miles and it stopped.
86 951 - VEMS
95 M3 LTW - S54 http://www.bmwmregistry.com/detail.php?id=15735
17 GTI
Sold: 97 M3/4/6 Byzanz, 99 M Coupe, 02 M Coupe
Jump to top SamGrant951 is offline   Reply With Quote
Old Wed, May-15-2019, 04:04:53 PM   #8
HassanEido
HassanEido's Avatar
Lebanon
It'll smoke from header coating happened to me. On the dyno. Like.. 5 years ago
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Wed, May-15-2019, 05:49:20 PM   #9
stash1
Out the tail pipe Hassan, or just under the hood? I think that OP just mentioned (in post #5) that it's only smoking from the tail pipe. OP, does it smoke all of the time, or just at start up/idle? I just can't see how a tune would make a car smoke unless you blew a head gasket or something already? Have you driven it hard yet since the header/tune install, or has it just been sitting there idling in your garage so far?
Old Wed, May-15-2019, 06:16:16 PM   #10
SamGrant951
tailpipe
86 951 - VEMS
17 GTI
Discussing Headers and ECU Tune now I have white smoke in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
