Old Wed, May-15-2019, 01:43:18 PM   #1
djhop1234
Reputation: 0 djhop1234 is on a distinguished road
Default Dealer says thermostat needs replaced
Hi,
Finally took my 04 with 96k in for the driver airbag and dealer says Thermostat needs replaced $775. There was no codes when I dropped it off.
Can they really tell from a inspection on whether its bad?
I had planned on a cooling system overhaul this winter when it was closer to 100k and prefer to wait if possible and do both the thermostat and water pump at an Indy at the same time.
Jump to top djhop1234 is offline   Reply With Quote
Old Wed, May-15-2019, 01:55:26 PM   #2
rovert604
rovert604's Avatar
Default Re: Dealer says thermostat needs replaced
GG I think I bought my thermostat for $40 and installed it in an hour with little coolant loss. Just a quick top-up/bleed and was good to go!
--Trevor in 604--
Vancouver, BC, Canada
Old Wed, May-15-2019, 02:09:54 PM   #3
Drewster
Drewster's Avatar
Originally Posted by djhop1234 View Post
Hi,
Sounds like BS - ask them to show you why it's bad
Old Wed, May-15-2019, 02:46:58 PM   #4
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
$775 to change a $50 Tstat? I just replaced my entire cooling system for around the same price. Radiator, Pulleys, Belts, Water Pump, Tstat, and installed a Electric Fan with N15 mounts.
Old Wed, May-15-2019, 03:00:11 PM   #5
djhop1234
$775 to change a $50 Tstat? I just replaced my entire cooling system for around the same price. Radiator, Pulleys, Water Pump, Tstat, and installed a Electric Fan with N15 mounts.
Yep.... Crazy huh. They also wanted $225 to replace a turn signal that had moisture in it.
Old Wed, May-15-2019, 03:07:00 PM   #6
Whitehawk8
Whitehawk8's Avatar
Reputation: 0 Whitehawk8 is on a distinguished road
Highly recommend you try it yourself. Super easy to do.
$40 part. Buy the Wahler brand one - its OE.
Like wolf I replaced my entire cooling system for about that price
The dealer said my freshly flushed brake fluid needed to be replaced. Literally flushed a week before...
2003 M3 StahlGrau Metallic | Beisan | JB Racing | Koni | CMP | TMS | OEM SSK
Jump to top Whitehawk8 is offline   Reply With Quote
Old Wed, May-15-2019, 03:07:32 PM   #7
jbfrancis3
Reputation: 0 jbfrancis3 is on a distinguished road
How is your temp gauge behaving? But yes $775 seems nuts.
'05 M3 Convertible, Carbon Black/Cinnamon.
Jump to top jbfrancis3 is offline   Reply With Quote
Old Wed, May-15-2019, 03:14:41 PM   #8
djhop1234
Ha same here on the Brake fluid (had it changed 3 wks ago).... I thought about changing the cooling system. Done a bunch of other work, struts, FCABs, RTABs, brakes and figure I can probably do this too.
Old Wed, May-15-2019, 03:15:45 PM   #9
Whitehawk8
Whitehawk8's Avatar
Hardest part about cooling system is getting the stupid lower radiator hose off the radiator. Itís STUCK on there lol
Old Wed, May-15-2019, 03:16:28 PM   #10
djhop1234
On really hot days last summer it would get just short of 3/4's when stopped in traffic. Then went back down as I drove. 95% of the time its right in the middle. I had the coolant changed 3 weeks ago trying to see if that would help it.
Discussing Dealer says thermostat needs replaced in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
