Old Wed, May-15-2019, 12:33:04 PM   #11
STAATS
STAATS's Avatar
Default Re: Who can convert my HP DME to stock CSL?
Originally Posted by Dr M3an M3 View Post
for a DME hardware conversion, it shouldn't matter that you don't use their map sensor kit. Just scale the tune for whatever MAP sensor you're using.
+1
STAATS
Old Wed, May-15-2019, 02:31:52 PM   #12
DirtyEtzio
DirtyEtzio's Avatar
Reputation: 0 DirtyEtzio is on a distinguished road
Originally Posted by lippstuh View Post
I have one but it's just a canned tune; not a dyno tune. I have hesitation in low rpm and high load. We need to resolve it but haven't found the time.
Outside of that, solid power gains.
Have someone check the WOT tables around the rpm you're having the stumble....
Sent from my SM-G955U using Tapatalk
  • MCS 3-way Remotes, front/rear Hotchkis sways
  • Some sort of crazy DiffsOnline 3.91 diff
  • SuperSprint V1.
    BW Race Exhaust.
  • Essex AP Racing 9668 front brake kit
Jump to top DirtyEtzio is offline   Reply With Quote
Old Wed, May-15-2019, 02:41:09 PM   #13
PITT M3 RR
PA
PITT M3 RR's Avatar
My 2 cents on Kassel...be careful. Jim owes me an air box, I found mismatched o-rings in my "besian rebuilt vanos " a few days ago. The DME he swap tuned for me has a permanent error code for main relay voltage and if you'll search my most recent issue...he improperly timed my exhaust cam. I was able to discover this by learning how to do all these things myself over the years. Making a virgin swap DME exposed a lot of these things. Anything I got from him apart from the fuel pump kit has been an issue and caused a major headache.
I will say I dealt with him about 3 years ago when "they" (his partner behind the scene is or was out west) were newer, so maybe times have changed. Oh and the "tune" was hackenTTs tune he sold me with timing pegged at 26 degrees advance regardless of IAT or water temp. And, he up charged my almost $200 for Andrews harness from R3V after looking me dead in the eye and telling me he was making it in house.
Just be careful and get everything in writing.
S54 E36 BUILD
Old Wed, May-15-2019, 03:48:38 PM   #14
kokgo20
kokgo20's Avatar
What do you mean?
I only used Kassel for the hardware conversion of the DME to convert my HP DME to CSL....My conversion runs off the stock CSL map sensor...but for a DME hardware conversion, it shouldn't matter that you don't use their map sensor kit. Just scale the tune for whatever MAP sensor you're using.
I guess I should have explained in details, since their price is good on the DME conversion, I was gonna get their map sensor setup and retune since my blower is pumping more air now, and thinking of going direct methanol injection.
He mentioned that their map sensor wonít work on boost.
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + TTFS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Wed, May-15-2019, 03:55:06 PM   #15
mpwrcpe
The Throbbing Gristle
Reputation: 0 mpwrcpe is on a distinguished road
He mentioned that their map sensor won’t work on boost.
You already have a TTFS ECU, why not contact Frank? He is perfectly capable of the CSL conversion.
The Kassel MAP won't work because it's a 1 bar sensor, you need a 2 or 3 bar MAP. Frank uses GM sensors which are cheap, reliable and readily available.
__________________________________________
///'95 Avus M3 S54B32 Racecar
///'90 Calypso 325ic (70K miles)
///'72 Chamonix 2002 (Restoration project)
'15 Touareg TDI (Racecar hauler)
Jump to top mpwrcpe is offline   Reply With Quote
Old Wed, May-15-2019, 04:11:01 PM   #16
kokgo20
kokgo20's Avatar
Frank's HP DME conversion is $475, i was looking for something cheaper, i like Kassel's price $225
I may get Kassel to do the hardware conversion and Frank to re-tune.
I was wondering if any forum member who can / willing to do the conversion for a fee also.
Old Wed, May-15-2019, 05:20:38 PM   #17
If youíre not going to be installing the flap, you may as well skip the hardware conversion and use mssflasher to flash the modified version that works with the non-CSL boot sector.
Old Wed, May-15-2019, 05:58:25 PM   #18
ultimatemj
Wait, are you saying the conversion isnít needed to use a MAP?
2004 JB/Blk SMG | 2nd owner | Purchased Dec 2008 w/24k miles | Crossed over 100k mile Apr 2019
Key maintenance done @90k: Subframe reinforced | WPC Rod bearings | Beisan Vanos lockdown + chainguide
Refesh maintenance done: Suspension & Driveline rubber replaced | CSB | viton CPV | Coils + plugs+ O2s | Waterpump + Thermostat | Belts & pulleys
OE+ : Evolve airbox | Supersprint Exhaust | PE tune | CSL trunk | 18Ē VMR 710 w/PSS | EU OE 2pc Rotors | Koni+Dinan springs| Valentine1 w/StealthOne | Stereo build log
Old Wed, May-15-2019, 06:01:56 PM   #19
The hardware part, still need the csl tune with cam profiles corrected afaik.
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer/fog delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Wed, May-15-2019, 06:05:38 PM   #20
If you have an mss54hp, you can flash a modified version of the CSL software that will run without hardware modification.
Discussing Who can convert my HP DME to stock CSL? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
