Old Tue, May-14-2019, 11:29:34 PM   #1
kokgo20
kokgo20's Avatar
Default Who can convert my HP DME to stock CSL?
I understand that it needs to be on a bench.
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + TTFS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Tue, May-14-2019, 11:41:45 PM   #2
repoman89
repoman89's Avatar
Reputation: 0 repoman89 is on a distinguished road
Default Re: Who can convert my HP DME to stock CSL?
Kassel Performance in the states
Jump to top repoman89 is online now   Reply With Quote
Old Wed, May-15-2019, 01:24:39 AM   #3
ultimatemj
Performance Eurowerks in Buffalo Grove IL did mine.
2004 JB/Blk SMG | 2nd owner | Purchased Dec 2008 w/24k miles | Crossed over 100k mile Apr 2019
Key maintenance done @90k: Subframe reinforced | WPC Rod bearings | Beisan Vanos lockdown + chainguide
Refesh maintenance done: Suspension & Driveline rubber replaced | CSB | viton CPV | Coils + plugs+ O2s | Waterpump + Thermostat | Belts & pulleys
OE+ : Evolve airbox | Supersprint Exhaust | PE tune | CSL trunk | 18 VMR 710 w/PSS | EU OE 2pc Rotors | Koni+Dinan springs| Valentine1 w/StealthOne | Stereo build log
Jump to top ultimatemj is online now   Reply With Quote
Old Wed, May-15-2019, 01:45:46 AM   #4
lippstuh
lippstuh's Avatar
Reputation: 0 lippstuh is on a distinguished road
+1. They do 24hour turnarounds on DME work.
/// 2002 Jet Black 6MT Cinnamon
Mods
Karbonius CSL Airbox (1x1) w/ Snorkle CSL-spec DME Kassel MAP sensor Kassel Tuned
JIC Cross/ZMS RS coilovers 996 Brembo BBK w/ CSL/ZCP Rotors F+R Volk OG TE37 Bronze Michelin Pilot Sport 4S 265/35/18
OE CSL trunk OE LED taillights Llumar Air 80 Tint
Next
OZ Hamann PG1 18" custom build VCSL bumper JCSL Diffuser
Jump to top lippstuh is online now   Reply With Quote
Old Wed, May-15-2019, 02:28:26 AM   #5
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Yep. Very happy with mine (physical hardware conversion). Had both mine and a friends done at the same time in that 24hrs too. Also cool, they sent before and after pictures of their work and the prices were very affordable too. If I had to do it all over again, I'd make the same choice. Would be interesting to see more posts on here regarding their tunes? Anyone have a Kassel Tune? Mine had I think just the base CSL tune on it when I received it, but had PC tune it when it was put together, so can't speak much on the side of performance tunes.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2
Old Wed, May-15-2019, 02:30:12 AM   #6
lippstuh
lippstuh's Avatar
I have one but it's just a canned tune; not a dyno tune. I have hesitation in low rpm and high load. We need to resolve it but haven't found the time.
Outside of that, solid power gains.
Mods
Next
Old Wed, May-15-2019, 04:28:07 AM   #7
kokgo20
kokgo20's Avatar
Unfortunately Kassel can’t help much since their map sensor setup doesn’t support boost so there is no point of their CSL conversion
Old Wed, May-15-2019, 05:50:47 AM   #8
STAATS
STAATS's Avatar
TTFS can do it:
http://tuningtechfs.com/ttfs-e46-csl-ecu-upgrade/
They upgraded my non-HP to CSL-spec minus the flap (so just upgrade the chips to HP and load on the CSL program)... I also got their MAP sensor / air-rail setup... As it is a GM MAP sensor I dont see why they wouldn't be able to change it out for a MAP sensor to suit your boost range... then you just need to scale for it when you tune or whatever...
I vaguely remember this coming up in conversation before and somewhere between 2 and 3bar is the greatest range our ECU can deal with? maybe Terra will chime in, I am sure he is the one who cleared it up last time...
STAATS
Old Wed, May-15-2019, 05:53:29 AM   #9
STAATS
STAATS's Avatar
Sorry forgot to add that you can then get the stock-CSL tune file from here:
https://www.ecuworx.co.uk/downloads/
I can't remember exactly which one it is...
STAATS
Old Wed, May-15-2019, 06:28:15 AM   #10
Dr M3an M3
Dr M3an M3's Avatar
What do you mean?
I only used Kassel for the hardware conversion of the DME to convert my HP DME to CSL....My conversion runs off the stock CSL map sensor...but for a DME hardware conversion, it shouldn't matter that you don't use their map sensor kit. Just scale the tune for whatever MAP sensor you're using.
IG: DrM3anM3
Discussing Who can convert my HP DME to stock CSL? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
