Old Tue, May-14-2019, 07:32:05 PM   #1
LemonOne
LemonOne's Avatar
Reputation: 0 LemonOne is on a distinguished road
Default Driver side mirror tilts down or up randomly when I start the car
Is anyone having this issue?
Very annoying to adjust mirror every time I get int
2006 Imola Red / Cinnamon SMG II
Jump to top LemonOne is offline   Reply With Quote
Old Tue, May-14-2019, 08:08:25 PM   #2
AETBX
AETBX's Avatar
Reputation: 0 AETBX is on a distinguished road
Default Re: Driver side mirror tilts down or up randomly when I start the car
I have the same issue except it is the passenger side mirror tilts down randomly when I unlock the doors.
Jump to top AETBX is offline   Reply With Quote
Old Tue, May-14-2019, 08:44:43 PM   #3
LemonOne
LemonOne's Avatar
Any idea what's causing this?
Is this the Imola Red thing?
Old Tue, May-14-2019, 08:51:20 PM   #4
Steve M3
Nope, my Sahara Beige moves the mirror around when I unlock it
Jump to top Steve M3 is online now   Reply With Quote
Old Tue, May-14-2019, 09:07:58 PM   #5
LemonOne
LemonOne's Avatar
Seems to be a common issue?
https://www.m3post.com/forums/showpo...5&postcount=11
Old Tue, May-14-2019, 10:42:44 PM   #6
James31
Reputation: 0 James31 is on a distinguished road
turn your power mirror switch in the other direction.
Jump to top James31 is offline   Reply With Quote
Old Tue, May-14-2019, 10:50:13 PM   #7
Texaz3
The switch only turns the mirror down when you put the gear in reverse - this is a feature that helps to see the opposite side curb when backing up.
But I do think there is something wrong with the mirror switch, where it does turn this feature when you open the door/car. At least I would start looking there first.
Old Thu, May-16-2019, 02:04:35 AM   #8
exodus454
Reputation: 0 exodus454 is on a distinguished road
When you get the mirrors and everything set back where you like it, hit the M button on the seat (should light up red), then hit 1. Hit M again and then hit 2.
If the memory presets get cleared out they'll do strange things. They should be moving back to whatever you saved when unlocking, if you have multiple keys it won't necessarily be the first memory position.
If this doesn't fix it there's probably a problem elsewhere.
05 ZCP - 6MT >> CPI Stepped Headers - Magnaflow cats & 1 Cherrybomb - Meisterschaft Titanium - CSL software - Eibach pro kit - 15mm rear spacers - BW studs - GC Hybrid FCABS - BW Spherical RTABS - TMS front bar
Manual Leveling - Factory Xenon - Nightbreakers - ZKW-R lenses
Jump to top exodus454 is offline   Reply With Quote
Discussing Driver side mirror tilts down or up randomly when I start the car in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
