Old Tue, May-14-2019, 08:58:07 PM   #11
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
Default Re: Anyone have experience with RK Tunes?
Originally Posted by Rich.7 View Post
What do you recommend?
MAP > Alpha N because it is available
Topo Chico
Old Tue, May-14-2019, 09:04:47 PM   #12
erickrayos
I'd love to run MAP if its guaranteed to be able to connect to smog center computers. so far it seems like it depends on the smog testing centers themself if they got the updates to connect to it.
Jump to top erickrayos is online now   Reply With Quote
Old Tue, May-14-2019, 09:08:10 PM   #13
repoman89
repoman89's Avatar
Reputation: 0 repoman89 is on a distinguished road
Originally Posted by erickrayos View Post
the problem with the smog. connecting to the smog computers w/ CSL DME seems to be more of a miss than a hit.
Flash it back and forth so you only have to run alpha-N for inspection day. I started a thread a couple weeks ago about CSL DME and inspection in which TerraPhantm posted how to modify the US tune to work on the CSL DME with regular flashing tools.
Jump to top repoman89 is online now   Reply With Quote
Old Tue, May-14-2019, 09:26:30 PM   #14
Rich.7
Reputation: 0 Rich.7 is on a distinguished road
What's the benefit of having to go through those extra steps?
Jump to top Rich.7 is offline   Reply With Quote
Old Tue, May-14-2019, 11:44:02 PM   #15
repoman89
repoman89's Avatar
Stock US and CSL software are not interchangeable except with a BDM bench flash setup. Modified tunes let you use a tool like MSSFlasher to write working versions back and forth so your tune is guaranteed to work with the emissions computers but can be a CSL MAP tune every day except inspection day
Old Tue, May-14-2019, 11:54:46 PM   #16
erickrayos
aren't you limited to how many flashes you can do w/ the DME before it bricks itself? iirc it was like 16 times or so.
Old Wed, May-15-2019, 12:16:11 AM   #17
repoman89
repoman89's Avatar
MSSFlasher can reset it
Old Wed, May-15-2019, 02:31:59 AM   #18
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Yessir. MSSFLasher is a must have if you mess with tuning. Very fast flashing (literally often times in seconds to completion) and it's the only tool I'm aware of that reset the flash counter.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2
Old Wed, May-15-2019, 04:05:32 AM   #19
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Originally Posted by Dr M3an M3 View Post
Yessir. MSSFLasher is a must have if you mess with tuning. Very fast flashing (literally often times in seconds to completion) and you can revirginize the DME to reset the flash counter.
You mean “Reset Flash Count” not “Virginize” DME as that would erase everything.
Old Wed, May-15-2019, 06:21:25 AM   #20
Dr M3an M3
Dr M3an M3's Avatar
Doh! Yes, exactly this. Thanks, editing my previous post to avoid confusion.
IG: DrM3anM3
Discussing Anyone have experience with RK Tunes? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
