Old Tue, May-14-2019, 01:53:28 AM   #1
aznniche
aznniche's Avatar
Default Underdrive pulleys - stiff steering
Since I installed my TMS power pullies, the steering is very stiff and hard to turn when the car is stationary. Parking is harder since I have to put two hands to turn the wheel. Once The car is moving, the steering is normal.
Is this normal? I bled the power steering with both wheels in the air turning right to left around 20 times but this didnít help.
Old Tue, May-14-2019, 01:55:43 AM   #2
Whitehawk8
Whitehawk8's Avatar
Reputation: 0 Whitehawk8 is on a distinguished road
Default Re: Underdrive pulleys - stiff steering
Yes itís called ďunderĒ driving.
Less effort is used to doing things like the PS pump and water pump. That results in them working less. Giving you less power steering
2003 M3 StahlGrau Metallic | Beisan | JB Racing | Koni | CMP | TMS | OEM SSK
Jump to top Whitehawk8 is offline   Reply With Quote
Old Tue, May-14-2019, 03:30:14 AM   #3
Paulo M
Curious why you installed under drive pulleys without knowing this as an outcome. It’s one of the main reasons people go with them.
BREMBO APEX DIXIS
Old Tue, May-14-2019, 03:37:54 AM   #4
rbg
Reputation: 0 rbg is on a distinguished road
Honestly, I was so hoping for that to happen, but still find sterling too soft.
Jump to top rbg is online now   Reply With Quote
Old Tue, May-14-2019, 11:14:23 AM   #5
aznniche
aznniche's Avatar
I knew it would be stiffer, but not to this extent when car is stationary. May remove it since the power results are negligible.
Old Tue, May-14-2019, 11:18:44 AM   #6
HassanEido
HassanEido's Avatar
Lebanon
u might have a bad ps pump. now when u say both hands...I've never used 1 hand to turn the M3 steering wheel...I feel like u're describing the wrong car lol.I mean it's not a Cadillac when stock. But when I had a bad ps pump it was tough to move the wheel. I have tms pulleys and the difference in steering effort is near neglible..maybe its a tad stiffer? But i drive stock m3s all the time and they feel similar.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Tue, May-14-2019, 12:22:45 PM   #7
Paulo M
If it’s that big of a change, then there’s something wrong. Install, bad part, or other worn items. I drove mine to the shop to have mine done and drove home immediately after install. Noticeable but feels stock after 30min of driving once you’re used to it.
Removing them is good move. And no power is made from it really. Hopefully you regain that stock steering again.
BREMBO APEX DIXIS
Old Tue, May-14-2019, 12:30:27 PM   #8
HassanEido
HassanEido's Avatar
Lebanon
yeah, zero power made from pulleys..then again I have blingy aluminum pulleys under the hood.. lol
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Tue, May-14-2019, 02:08:47 PM   #9
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Jump to top CrookedCommie is online now   Reply With Quote
Old Tue, May-14-2019, 05:16:36 PM   #10
aznniche
aznniche's Avatar
I don't think I have a bad PS pump since it works fine while driving. When I bled the system, I had both front wheels off the ground and the steering wheel moved easily.
Think I'll verify by I stalking my stock pullies on when I do my valve adjustments.
Discussing Underdrive pulleys - stiff steering in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
