Old Tue, May-14-2019, 07:39:21 PM   #31
Whitehawk8
Whitehawk8's Avatar
Reputation: 0 Whitehawk8 is on a distinguished road
Default Re: OEM Rotors or CSL?
Originally Posted by OldFanatic View Post
well the front CSL rotors will need the larger carriers to clear. and the technically "correct" way is to have the CSL rear calipers with the larger piston(although many don't do this). it's a brake bias thing.
i'd go CSL rotor route. especially if youre consdering a caliper kit that uses the CSL rotors down the line.
the aluminum hats and (floating) design of rotors along with perforated rotors really sheds some weight and assists the temps.
I think I値l be going this route.
I already have some spare CSL calipers and carriers.
The fact that most BBK upgrades go off of the CSL rotors is definetly a plus as well.
And if I知 ever doubting them (cracking) I値l just replace em
2003 M3 StahlGrau Metallic | Beisan | JB Racing | Koni | CMP | TMS | OEM SSK
Jump to top Whitehawk8 is offline   Reply With Quote
Old Wed, May-15-2019, 07:39:38 AM   #32
C///M
Hey - if you ever go the 996 route, I have a set of never used rear rally road brackets since I went with P0lar's brackets. I'm great at buying stuff I never use...
Sent from my Pixel 2 XL using Tapatalk
Jump to top C///M is online now   Reply With Quote
Copyright ゥ1999-2017 M3Forum.com
Discussing OEM Rotors or CSL? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
