Old Tue, May-14-2019, 12:57:18 AM   #1
Whitehawk8
Whitehawk8's Avatar
Reputation: 0 Whitehawk8 is on a distinguished road
Default OEM Rotors or CSL?
Trying to decide which rotors I should choose and thought you guys know best. Keep in mind price is no issue because of FCP warranty. Also keep in mind that these are my ONLY 2 choices. My car is a daily driver that sees between 5-10 track days a year.
OEM Rotor (Blank)
Pros:
-Not prone to cracking
-Lower Heat Cycling Spikes because of increased Mass
Cons:
-No BBK upgrade
-No Where for pad buildup to go?
CSL Rotor
Pros:
-996 BBK upgrade available
-Holes for Pad buildup to escape?
-Looks freakin awesome
-More "edges" leading to better braking?
Cons:
-more prone to cracking
As of now Im more leaning to the CSL rotor because im thinking of a future 996 BBK. Somebody help me make the right choice. Thank you!
2003 M3 StahlGrau Metallic | Beisan | JB Racing | Koni | CMP | TMS | OEM SSK
Jump to top Whitehawk8 is offline   Reply With Quote
Old Tue, May-14-2019, 01:08:06 AM   #2
Default Re: OEM Rotors or CSL?
I would get euro 325mm. For weight savings and slight bling. If no plans on 996 brembo conversion.
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
Old Tue, May-14-2019, 01:10:55 AM   #3
Whitehawk8
Whitehawk8's Avatar
Question. Why those instead of CSL?
Correct me if im wrong but euro rotors are US size but drilled?
Old Tue, May-14-2019, 01:11:52 AM   #4
lmtfi
lmtfi's Avatar
1. OE blanks.
2. BBK gains you nothing.
3. Pad buildup?
Old Tue, May-14-2019, 01:11:55 AM   #5
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Their semi floating like the csl
Jump to top Blaikenstein is offline   Reply With Quote
Old Tue, May-14-2019, 01:13:38 AM   #6
Blaikenstein
Iím going with the stock 325 rotors and will upgrade to the euro 325. With the db9 vagbratechnic kit you have both 325 and 345 options
Old Tue, May-14-2019, 01:23:29 AM   #7
Whitehawk8
Whitehawk8's Avatar
Originally Posted by lmtfi View Post
1. OE blanks.
3. Pad buildup?
What do you mean BBK gains nothing? Much harder to overheat those brakes when they're bigger!
Heres an article on pad buildup https://www.zeckhausen.com/catalog/i...Path=6446_6444
I put a question mark because I was unsure if the holes would help with this issue. Its one that I have on track
Old Tue, May-14-2019, 01:38:35 AM   #8
lmtfi
lmtfi's Avatar
Drilled rotors heat stress much easier from track use. If you are beating on rotors as hard as you suggest from your comment - then you are clearly increasing your chance of a rotor crack ending your HPDE weekend.
If you need better rotors due to extreme use (I assume you are running sessions substantially longer than the typical 25-30 minute sessions) - go with PFC Direct Drives.
Standard brake cooling practice at the track will avoid imprinting.
Old Tue, May-14-2019, 01:55:25 AM   #9
M3AZ
///M3AZ
M3AZ's Avatar
Reputation: 0 M3AZ is on a distinguished road
If you’re going the FCP Euro route there are no real cons to the CSL rotors. I have a similar plan to run the CSL rotors, then possibly upgrade to the 996 brakes.
The two benefits you didn’t mention are that the floating rotors have better heat dissipation, and the rears will reduce unsprung weight 2 lbs per corner. Some say the floating rotors also reduce pad and bearing wear.
██████████████████ 2003 E46 M3
Old Tue, May-14-2019, 02:02:54 AM   #10
Whitehawk8
Whitehawk8's Avatar
my track sessions don't usually go on longer than 30 minutes but yes sometimes they do
Do you think that a 30 minute session will be too hard on a CSL rotor?
Discussing OEM Rotors or CSL? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
