Old Mon, May-06-2019, 03:45:49 PM   #1
kokgo20
kokgo20's Avatar
Default Gauging interest in building custom digital gauges
Gauging interest in building custom digital gauges, fitted into about anything, for any make or model.
Examples of my gauges
E46
E90
PM with what functional you need and preferred place for a quote.
For a faster response, text 901-214-5345
Thanks in advance
Joe
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + TTFS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Mon, May-06-2019, 06:36:40 PM   #2
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Default Re: Gauging interest in building custom digital gauges
I’ve seen the same setup for E36 vent.
Told the guy it would be nice to have matching dot-matrix displays instead of 7-segment LCD.
Old Mon, May-06-2019, 07:48:31 PM   #3
kokgo20
kokgo20's Avatar
Good call, will check if it’s available to have on the gauges
Old Thu, May-09-2019, 01:07:25 AM   #4
M3AN
321 fun...
M3AN's Avatar
New Zealand
I might be keen but I'd need to see a finished e36 product first I think. The pics above look good but that doesn't necessarily translate.
Where do you anticipate they'd fit? Any further thoughts on a matching dot matrix display?
I'd want oil pressure, oil temp and possibly A/FR.
100% needs to be in metric rather than rocks and pebbles.
/// E36 M3 Coupe / Estoril Blue / Lotus White
/// S50B32 / 6MT / Slick Top / Alu Doors / Z3 Rack / Simota / Remus / Bilstein B6 / Eibach Pro+ / BBS RC / Goodyear F1 / Rally Road Bits / 3.62 CWP (TBI)
Old Thu, May-09-2019, 02:12:06 AM   #5
I have to agree on dot matrix for E36 use.
Old Thu, May-09-2019, 03:38:46 AM   #6
kokgo20
kokgo20's Avatar
Unfortunately my supplier doesn’t have dot matrix.
As far as the E36 application, it will look exactly the same as the E46 except in the E36 vents.
Old Thu, May-09-2019, 05:18:08 AM   #7
M3AN
321 fun...
M3AN's Avatar
New Zealand
The e36 has a single, asymmetrical centre vent and the side vents are also asym... so it won't be able to look the same as the e46 version, it will need to be e36 specific, for the centre the panel will need to be much wider. Although I'd probably prefer the RHS vent (RHD car).
This is why I'd want to understand what you had planned.
Old Thu, May-09-2019, 09:05:06 AM   #8
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
I'd likt to know where the gauge gets its data from. Don't need an extra oil temp to install somewhere. It should be read directly off the DME, although I have a feeling this may not be the case.
That's where the OpenOBC could've (should've?) been the ultimate solution. 100% factory look, with option of displaying all DME data.
M3AN: don't have it at hand, on IG there is a pic of the E36 version of this setup. Much better than the ugly prototype Awron gauge solution.
Old Thu, May-09-2019, 10:16:47 AM   #9
M3AN
321 fun...
M3AN's Avatar
New Zealand
Actually, 90's perfection for additional info was that VDO addition in front of the cluster... was that in some ACS cars? I saw one with cables but no sensors (not sure if they used stock sensors) go on eBay for EUR1000 in about 2014... ouch.
But back on topic, still interested in more details on the option here. I don't have a problem if there's still stuff to work out, that's to be expected and am happy to contribute to the discussion.
Old Thu, May-09-2019, 11:48:55 AM   #10
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
That will be the Alpina gauges. This came with tons of additional wiring, numerous sensors, Alpina oil filter cap and a module to control it all.
I wouldn't call it nicely intergrated, but they do look cool.
I haven't seen a set for sale for years. And if a complete set would pop up, €1000 will not get you far.
Discussing Gauging interest in building custom digital gauges in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
