Old Mon, May-06-2019, 01:21:30 PM   #1
11b4
11b4's Avatar
Default Ecs vs bimmerworld vanos line?
Anyone know the difference between them? The ecs one looks like it fits snug next to the engine, compared to the bimmerworld which has some space from the engine which might help with heat issues. Anybody know the stats to compare both. Pretty curious because I'm looking to update my vanos line during the next oil change.
Old Mon, May-06-2019, 01:27:32 PM   #2
.'s Avatar
Reputation: 0 . is on a distinguished road
Default Re: Ecs vs bimmerworld vanos line?
Can't really tell you whcih is better. I've been running the BW for a few years now with no issues after my factory one sploded. A lot of people will probably tell you to just get the updated OEM hard line. I don't really care for the hard line when it comes to working on my motor a lot but that may be a non issue for you.
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, Kassel CSL DME & MAP conversion, Paul Claude tune, TMS Power Pulleys, SS V1 stepped headers & catless section 1, SS 2.5 twin-piped resonated section 2, SGT scza section 3.
Drivetrain: DKM Stage 2 Clutch, RTD V2 mini shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings.
Suspension/Brakes: Bilstein PSS9's, RE RSM's, UUC sway bars, BW camber arms, TMS monoball RTABs, ZCP rotors, BW solid caliper guide bushings, PFC 08's, Motorsport Hardware 75mm stud kit.
Interior: Cobra Nogaro seats, BMW Performance shift knob/e-brake/pedals, OE alcantara boots, mason clutch pedal, Xtrons 9" headunit w/ carplay
IG: Zach_e46M
Jump to top . is offline   Reply With Quote
Old Mon, May-06-2019, 01:46:52 PM   #3
JaredMV
Amateur Weekend Mechanic
JaredMV's Avatar
The thing that prevented me from going with the Bimmerworld or ECS line was that it was considered an "annual maintenance item" in the description. Whether that's the case or it was just a misunderstanding of the wording, I wouldn't buy anything that needs to be replaced on a maintenance schedule if the updated OE line acts as a one-time fix. If ECS and/or Bimmerworld could confirm that it doesn't need to be replaced every year, I'll return my updated OE hardline and get a braided line.
JaredMV's M3 Touring Build: http://www.m3forum.net/m3forum/showthread.php?t=604213
Originally Posted by Jaredomin View Post
8k shipped. Lmk thanks
Old Mon, May-06-2019, 02:14:24 PM   #4
SamGrant951
SamGrant951's Avatar
Reputation: 0 SamGrant951 is on a distinguished road
I run the BW line and keep a spare with me @ the track, I really cant see how that would be an annual maintenance item.
86 951 - VEMS
95 M3 LTW - S54 http://www.bmwmregistry.com/detail.php?id=15735
17 GTI
Sold: 97 M3/4/6 Byzanz, 99 M Coupe, 02 M Coupe
Jump to top SamGrant951 is offline   Reply With Quote
Old Mon, May-06-2019, 02:53:45 PM   #5
robgill
I'd rather be at the track.
robgill's Avatar
Reputation: 0 robgill is on a distinguished road
Ive been running the BW (Rogue Engineering?) line for four years, no issues.
My '02 E46M Build Thread
Jump to top robgill is offline   Reply With Quote
Old Mon, May-06-2019, 03:00:41 PM   #6
stash1
Sounds like disclaimer wording to avoid warranty issues-lol. I’ve had the Rogue one for around 4yrs. as well...no issues either.
'04 AW/IR...some mods
Old Mon, May-06-2019, 03:19:26 PM   #7
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Soft lines aren't lifetime.
Old Mon, May-06-2019, 03:54:13 PM   #8
11b4
11b4's Avatar
From what I was tracking. A these braided lines are a better solution, not a annual replacement. Also that the hardline can't handle the amount of psi the braided SS line can handle. As well the flex in the line won't crack after multiple heat cycles unlike the oem hardline which is prone to cracking after awhile. Don't track guys replace the hardline once a year because of that? Anyways I was always under the impression that replacing it was going to be a one time thing compared to oem.
Starting at 10:24
Old Mon, May-06-2019, 04:03:50 PM   #9
CrookedCommie
Captain Slow
Bulgaria
You are over thinking it. Buy either and don't worry about it.
Old Mon, May-06-2019, 04:05:45 PM   #10
11b4
11b4's Avatar
I'm not overthinking it at all. I'm just curious what people's opinions are between both, or what other better options are out there other then the oem hardline.
Discussing Ecs vs bimmerworld vanos line? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
