Old Sat, Apr-27-2019, 03:58:35 AM   #1
NYCBMW
NYCBMW's Avatar
Reputation: 0 NYCBMW is on a distinguished road
Default 99’ 40K Mile M3 Vert - maintenance?
Hello,
I recently acquired a 99’ M3 Vert, with just under 40k miles. It’s unfortunately an automatic, but couldn’t pass on such a low mile example. It’s also entirely stock.
So far I have done the following:
1. Fresh Painted Bumper and new OEM front splitter
2. Huper Optik Ceramic (20% and 50% on windshield)
3. New OEM clear corners, side markers, and tail lights
4. New Bosch Ellipsoid Headlights
5. New moldings all around (front, rear, sides)
6. New Stromung staggered exhaust
7. BAV Sound Stage 1 speakers
8. CD43 Head Unit
Now I’d like to start on preventative maintenance.
What would be the first things to take care of on a 20yr old, low mileage E36 M3?
I am thinking the following:
1. Oil Change and replace oil filter
2. Flush Brake Fluid and bleed ABS pump
3. Flush Differential Fluid
4. Flush Coolant
5. Replace all air filters
6. Replace fuel filter
Any of these non essential? Also, any other items that need to be changed because of age and not necessarily wear and tear given only 40K miles?
Any advice is much appreciated.
Here she is when she arrived, will post updates once back from the shop!
Jump to top NYCBMW is offline   Reply With Quote
Old Sat, Apr-27-2019, 07:48:58 AM   #2
bluptgm3
Default Re: 99’ 40K Mile M3 Vert - maintenance?
Valve cover gasket, oil filter tower gasket.
Power steering fluid (D4 ATF).
Transmission fluid (D4 ATF) and filter.
FLCA Bushings
RTA Bushings (add RTA Toe Limiters)
Old Sat, Apr-27-2019, 01:06:02 PM   #3
I would do a 5 or 6 speed manual conversion and drive the car. It is great the last owner preserved it for the next owner but I hope it finally gets driven and enjoyed.
Old Sat, Apr-27-2019, 01:17:52 PM   #4
Texaz3
If this hasn't been done yet, I'd start with cooling system overhaul. Pump, TS, housing, hoses, belts, tensioners, fan clutch. Easy to do and not very expensive. Then plugs, all filters, all fluids.
Old Sat, Apr-27-2019, 06:18:27 PM   #5
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
You have the options list or can you do a VIN decode?
I’d like to see that spoilet listed as a factory fitted item.
To bad you swapped for clears. Amber looks fantastic on silver.
Old Sat, Apr-27-2019, 06:28:31 PM   #6
NYCBMW
NYCBMW's Avatar
FLCA Bushings
Thank you! Gonna have them price this up.
Old Sat, Apr-27-2019, 06:29:04 PM   #7
NYCBMW
NYCBMW's Avatar
Don’t mind it being auto for now, once the trans goes, then I’ll consider a swap
Old Sat, Apr-27-2019, 06:29:24 PM   #8
NYCBMW
NYCBMW's Avatar
How much do you suspect a cooling system overhaul costs?
Old Sat, Apr-27-2019, 06:32:12 PM   #9
NYCBMW
NYCBMW's Avatar
I believe this spoiler is a dealer installed part... I was on the fence of taking it off, but gonna leave it be for now.
As for Ambers, the black rubber linings we’re starting to crack and dry out. So decided to try to clear look... I’ll order a set of Ambers for when I get bored of the clear.
Old Sat, Apr-27-2019, 10:34:53 PM   #10
Contracheatcode
Reputation: 0 Contracheatcode is on a distinguished road
Congrats on the purchase. I am a 6 month owner. Check out my build journal for thoughts on what maintenance to start.
Jump to top Contracheatcode is offline   Reply With Quote
Discussing 99’ 40K Mile M3 Vert - maintenance? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
