Old Fri, May-03-2019, 09:45:20 PM   #31
zingbmw
Reputation: 0 zingbmw is on a distinguished road
Default Re: Help removing head
Originally Posted by sapote View Post
All the EX valves were not hitting the pistons, but they hit their mates IN valves instead!!!
This makes sense because only the IN cam bolts were sheared and the EX cam was in perfect timing.
Interesting that #1 two IN valves supposed to move in sync and hit the piston with same intensity and damage but why pic shows only the inner valve with damage and the outer valve sit lower.
The piston damage is not bad as I thought, so I think the bottom end is ok to be used as is.
the inner valve is sitting lower and there is damage on the inner valve side of the piston.
What are my options with the block? Can I easily remove just one piston without dropping the engine or do i have to drop the engine to remove the piston? Can I have someone machine the piston as it sits?
If the engine must be dropped in order to repair or replace the piston, what possible issues could I run into with just leaving the piston as is?
Jump to top zingbmw is offline   Reply With Quote
Old Sat, May-04-2019, 12:10:45 AM   #32
sapote
Why you need to change the slightly ding piston? I don't see the impact force was big enough to concern. (With a helper feeding the chain, you turn the crank CW looking rearward to feel any high spot during turning. Also turn to have each piston at its highest and compare this measurement to the other pistons; any difference indicates a bent rod or piston pin.)
If you need to change one piston, just remove the conrod bearing cap then pull the piston/rod up out.
Old Sat, May-04-2019, 12:19:14 AM   #33
sapote
How many miles on engine and do you feel the cylinder wall top ridge (smooth or step), and what condition of the cylinder honed cross lines?
My e46 323i cylinder wall still had clear hone lines and no detectable ridge at 160K miles.
Old Sun, May-05-2019, 07:42:41 PM   #34
zingbmw
thanks sapote. any other opinions on the piston? Will see what the local head shops say about the piston tomorrow.
Old Tue, May-14-2019, 07:28:24 PM   #35
zingbmw
should I leave the piston as is, clean it up, or have it replaced? It would probably be ~1000 in labor to replace it with the head already off.
Old Tue, May-14-2019, 08:30:24 PM   #36
sapote
I would just leave the pistons as is.
...do you feel the cylinder wall top ridge (smooth or step), and what condition of the cylinder honed cross lines?
Old Tue, May-14-2019, 08:31:00 PM   #37
ThunderMoose
Me too
#67 2017 NASA TX TT3 Champion
Old Wed, May-15-2019, 01:14:34 AM   #38
black bnr32
Reputation: 0 black bnr32 is on a distinguished road
I left my pistons as is when it happened to me. Just cleaned them and sanded down any sharp edges. Then put some new valves in and lapped them. Every thing else in mine was in good shape and in spec. Guides, valve seats, etc.
I used this valve spring compressor: https://www.princessauto.com/en/deta...or/A-p8003725e
Jump to top black bnr32 is offline   Reply With Quote
Old Wed, May-22-2019, 12:07:22 AM   #39
zingbmw
Sounds good thanks guys!! Will sand it a little and clean it up. How did you guys go about cleaning the carbon and oil off the pistons?
Will work on cleaning the pistons, while the machine shop is fixing the head. Was quoted 650 for labor plus parts. Any good source for valves and any other parts Ill need to source for the shop to replace? was considering picking up a used head for parts if they tell me that most of the valves are bent. Used heads seem to run ~500 on ebay.
Any good post detailing all the washer, gaskets, ect that I will need to put it all back together or maybe a kit including everything from someone like ecs?
Old Sat, May-25-2019, 12:38:58 AM   #40
zingbmw
Was told I need 6 intake valves. Also that the exhaust valve guides are in spec, but close to the limit. Are the exhaust guides commonly worn in this car or will they stay in spec for the life of the engine?
Any good source for intake vales or guides? the head guy asked me to source my own.
As for whats needed to put the car back together after getting the cylinder head back...
Ive been told to stick to the oem valve cover gasket and head gasket. considering getting elring or victor reins for the rest of the gasket/seals in the kit.
https://www.ecstuning.com/b-genuine-...t/11127831920/
Head gasket kit (oem headgasket and valve cover gasket...rest aftermarket)
intake valves $50 a piece oem
exhaust valve guides ??
Oil change kit
coolant
Coolant hoses (worth changing or switching to silicone?)
intake cam shaft bolts (do i need exhaust as well or just clean and locktite?)
vanos high pressure hose (flex or new stiff line?), vanos solenoid (havent done it yet), vanos chain guide
camshaft alignment tool (oem) (Is this is all I need specialty tool wise?)
valve adjustment
ac belt (its cracking)
intake and exhaust cam shaft sensors (is it worth swapping them for their upgraded parts while im here?)
Any thoughts? Any other specialty tools or parts im missing or any other maintenance I should do while the head is out?
Discussing Help removing head in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
